- Thank you received: 3
Starter for high compression drag engine.
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- zed1015
- Thank you received: 1548
The Honda starter is 12v not 24v and so is any other onboard starter that fits these engines.Looking to convert my KZ1000 (1200cc) drag engine to self start. It 16:1 compression so I’ll need to run 24v starting. Whats the recommended starter for this application? CBR900 has been suggested but what year?
The later J/GPZ 4 brush starters are the strongest and the usual go to for higher comp motors.
Ricks Motorsport also does a new higher torque starter for the KZ which is on par with the J/GPZ item.
All of which are 12v.
- Thank you received: 2281
- F64
- 81-KZ440D2
- Thank you received: 394
Run the same size ground wire to the engine case.
Then get a battery that can supply more current at 12v than your current battery.
81-KZ440-D2.
LIC, NY
- TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Injected
- Thank you received: 523
These are the cores generally used to make a "Super" starter but they get rewound to handle the extra current. I believe the company that use to rewind them is no longer in business as the owner died.
The general practice is to light weight the stator end and run two batteries wired for 24V to start. The main battery to run coils/ignition is 10AH (usual min spec for MSD box) the secondary battery is 7AH wired to only run on the start button. Run them thru a Ford V8 starter solenoid.
Call Mike Law at RaceWorks Canada, he has built hundreds of these systems.
- TerryK
What was the company called? wrote: Starter - CB900-1100F 1980-83 marked "438" on the end, 0.8KW Mitsuba SM-220
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Injected
Note - That info is 6 year old
