- Thank you received: 142
Teramoto T-REV Air Box… thing.
- Stereordinary
17 May 2024 12:59 - 17 May 2024 13:09 #899196
by Stereordinary
A breeze from the west.
‘90 ZR550 Zephyr
Teramoto T-REV Air Box… thing. was created by Stereordinary
I was aimlessly browsing around on Webike last night, and ended up stalking fellow forum member Zaddict’s product reviews of parts installed on his ‘90 ZR550 Zephyr. One product in particular caught my attention, and that was the
Teramoto T-REV Air Box Type II
. Based on the description, and Zaddict’s review I sort of understand what it does, but I guess I still just don’t quite “get it.” Can anyone help me out with a lamen’s terms description? And I also don’t understand where it goes on the bike or how it’s installed. Maybe Zaddict, if you’re reading this, can you take a picture for me? By the sound of it, I think I might really like what it does, but I am still confused on exactly what that is.
Edit: Pardon the typo in the topic title, I can’t seem to change it. Would a mod mind fixing that? Thanks.
‘90 ZR550 Zephyr
Last edit: 17 May 2024 13:09 by Wookie58. Reason: Typo
- Thank you received: 2281
17 May 2024 13:17 #899197
by Wookie58
Replied by Wookie58 on topic Teramoto T-REV Air Box… thing.
I have corrected your typo, it appears to be a one way valve in the breather (some cars have a “poppet valve” in the airbox) not sure how much effect it will have
The following user(s) said Thank You: Stereordinary
- Injected
- Thank you received: 523
17 May 2024 13:38 - 17 May 2024 13:41 #899199
by Injected
Replied by Injected on topic Teramoto T-REV Air Box… thing.
Is this some sort of "poor" mans vacuum valve?
I have seen on board vacuum units for drag bike crank cases and they can be worth some HP but the are only used for racing. The idea is to make negative case pressure to help ring seal and reduce any pressure buildup under the pistons. Having better or bigger crank case venting helps but sucking on it helps more!
On a street engine I doubt you would see 1-1-1/2 HP on that little valve, for $190 without tax/ship is it worth it? You would never feel that increase.
The drag race vacuum setups are for really high HP Pro Stock and Pro Mod engines up over 500HP, still they are only worth about 10-15 HP but that could be the difference in winning a race or not.
Last edit: 17 May 2024 13:41 by Injected. Reason: info
The following user(s) said Thank You: Dragbike_Mike, howardhb, Stereordinary, Wookie58
- Stereordinary
17 May 2024 19:59 #899220
by Stereordinary
‘90 ZR550 Zephyr
Replied by Stereordinary on topic Teramoto T-REV Air Box… thing.
I think I mostly understand what you're saying, but I'm not really interested in it for any kind of HP bump. Here's a link to Zaddict's review:
japan.webike.net/prv/detail/1005703/p21717465/
. It's not so much a power boost, it's seems like it's just a sort of behavior of the motor kind of thing, I guess.
‘90 ZR550 Zephyr
- F64
- 81-KZ440D2
- Thank you received: 394
17 May 2024 21:40 #899222
by F64
81-KZ440-D2.
LIC, NY
Replied by F64 on topic Teramoto T-REV Air Box… thing.
I would be more concerned with oil vapor from your crankcase lowering your octane rating of your fuel as the oil vapor is going back through the carburetor.
You'll also be dealing with extra oil deposits on valves and carburetors.
It's not really environmentally friendly but I would run your crankcase vent hose outside the airbox and plug the hole in the airbox.
That may help your engine smoothness more than a $170 one way valve.
motorcycleproject.com/text/crankcase_recirc.html
81-KZ440-D2.
LIC, NY
- Injected
18 May 2024 06:22 #899233
by Injected
I could not read the tiny print in the first link. What your describing is a sort of surge reducer, if Kawasaki thought that was needed they would have already put it on there bikes. Hell it may be on some of there newer stuff buried under all that plasticI think I mostly understand what you're saying, but I'm not really interested in it for any kind of HP bump. Here's a link to Zaddict's review: japan.webike.net/prv/detail/1005703/p21717465/ . It's not so much a power boost, it's seems like it's just a sort of behavior of the motor kind of thing, I guess.
![:) :)](/media/kunena/emoticons/8.png)
- zed1015
- Thank you received: 1548
18 May 2024 07:04 - 18 May 2024 07:06 #899234
by zed1015
Replied by zed1015 on topic Teramoto T-REV Air Box… thing.
It's simply a one way intake powered suction valve to lower or create negative crankcase pressure and reduce pumping losses which as a result will increase horsepower.
The more common method often used on race bikes etc is to run a crankcase breather pipe into the exhaust link pipe or silencer with the opening pointing downstream towards the exit of the exhaust and the passing gasses create a pressure drop in the breather pipe and consequentially the engine crankcase.
Last edit: 18 May 2024 07:06 by zed1015.
The following user(s) said Thank You: F64
- F64
- 81-KZ440D2
18 May 2024 08:03 - 18 May 2024 08:04 #899236
by F64
81-KZ440-D2.
LIC, NY
Yep, I was wondering if they did that on motorcycles as I knew about slash cut evacuation for cars.
81-KZ440-D2.
LIC, NY
Last edit: 18 May 2024 08:04 by F64.
- gd4now
- Denco where did you go?
- Thank you received: 429
18 May 2024 08:23 #899237
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Teramoto T-REV Air Box… thing.
Back in the day cars in the US made use of a road pipe to allow the crank case to release pressure, it sort of sounds like that is what this does. Also just want to say good call out on Mike Nixon.
1977 KZ650 B1
- Zaddict
- Enjoying my Zaddiction!
- Thank you received: 58
29 May 2024 18:31 - 29 May 2024 18:32 #899989
by Zaddict
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Replied by Zaddict on topic Teramoto T-REV Air Box… thing.
I'm happy with the T-rev on my bike - the effect was much more noticeable than I expected. I didn't notice any power bump but it really smoothed out engine braking. It plugs into the airbox plenum where it connects to the crankcase breather elbow connector. I'll take a pic next time I have the air filter housing out.
That said, if you're going to spring for expensive, high quality Japanese mods that you don't really need but might enjoy, I'd highly recommend the AS Uotani ignition system - very noticeable power increase complete with ignition timing control and an RPM limiter -
japan.webike.net/products/21552786.html#recent-review-block
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Last edit: 29 May 2024 18:32 by Zaddict.
- Zaddict
29 May 2024 18:36 #899990
by Zaddict
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Here's my review of the ignition system. They should probably pay me commission
but it really it really did make a big difference.
japan.webike.net/prv/detail/1006482/p21586552/
There's another thread on here I started about installation. Loudvx helped so much with that, I miss him. RIP.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
- Stereordinary
29 May 2024 18:52 #899993
by Stereordinary
‘90 ZR550 Zephyr
I’ve had that ignition system on my wishlist since reading your review of it. It’s a little too pricey for me at this point, but maybe down the line I can make it happen.
The T-Rev though, sounds like something I might like, and I think I understand what you mean about how it’s installed.
‘90 ZR550 Zephyr
