Engine install kz1000
  • ronnieV
  • ronnieV's Avatar Topic Author
02 Mar 2024 07:25
#895825
I'm starting another relove of a 1978kz1000a.I for the 1st time installed the engine on its side. I have read many times this being done. It's worked out great doing it myself.
The following user(s) said Thank You: Mcdroid, Street Fighter LTD, sf4t7, howardhb, Wookie58
  • sf4t7
  • sf4t7's Avatar
Re: Engine install kz1000
02 Mar 2024 14:46
#895849
And probably less grunting this way
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: ronnieV, howardhb
  • Rryanflakz
  • Rryanflakz's Avatar
02 Mar 2024 16:06
#895853
Been there done that….works well
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
02 Mar 2024 22:32
#895867
We have done at least 6 or 7 bikes installing the frame over the engine. It works really well if there's a center stand already on the frame.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • ronnieV
03 Mar 2024 04:54
#895872
Why the center stand?
  • Kelly E
  • Kelly E's Avatar
03 Mar 2024 09:51
#895883
Once the frame is on the motor we can pick it up and put it on the lift table with a jackstand in the front. Then it's ready to start installing parts.
1983 Honda CB 1100F
And more
  • ronnieV
09 Mar 2024 05:59
#896213
Thank you Kelly,I like that idea. And this is why I love this site.im 64,ive owned and reloved many kz's and still learning .
  • RedPill
  • RedPill's Avatar
11 Mar 2024 14:56
#896300
I know it’s a radically different engines and weights, but went over the same thing with my brother and his YZ250.
He was trying to figure out some Rube Goldberg contraption to balance the bike and slide the engine in.
I was like, “Do you have a spare piece of cardboard or rug to prevent the engine cases from getting scratched up?”
I think the engine weighed around 30# and the frame maybe 7#?
Much easier to maneuver the light frame around the heavy engine than the other way around.
  • cartal
  • cartal's Avatar
22 Mar 2024 07:53
#896746
Brilliant. This is what I am planning on doing with my Kz1000LTD.
One question comes to mind: Apart from the center stand (which is a fantastic idea), are there any other parts that are worth your while installing BEFORE getting the engine in?
I´m thinking about battery box, wiring loom, etc.
C.
  • Kelly E
  • Kelly E's Avatar
22 Mar 2024 20:51
#896768
Everything was easy to install after the engine is installed.
1983 Honda CB 1100F
And more
The following user(s) said Thank You: cartal
