  • Page:
  • 1
  • 2
Cylinder scoring 10 Feb 2024 12:15 #895089
  • stinkfinger
  • stinkfinger's Avatar Topic Author
  • Thank you received: 11
Whelp, I pulled the head on my recently assembled 750 engine to repair threads that stripped in the cylinder block when re-torquing the head (another story).  Upon inspection, I found that all 4 cylinders have visible score lines present.  This is a brand new bore for 810cc pistons.  I can just barely feel them with my fingernail. The engine was run for maybe 15 minutes, first idle then slow break in cruise around the neighborhood.  Am I correct in assuming that this engine is F’ed?  Any idea what might have caused it?  I guess at the very least it will need a re-hone, but if I don’t know what caused it that will be throwing good money after bad.  Thanks for any advice.
1981 KZ750E, 2005 GasGas EC300, 2023 Husqvarna 701 Enduro
Last edit: by stinkfinger. Reason: Fix images
Cylinder scoring 10 Feb 2024 12:20 #895090
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
PLEASE, edit your post, and click "insert all" with your photos.  They will show up in high resolution then, instead of tiny thumbnails.
Thanks in advance...
Sorry for this trouble.  I'm not sure what could have happened, but letting the bike idle may have deprived the cylinders of needed splash lubrication on the cylinder walls.
Did you oil the piston skirt before install?  What kind of oil are you using?
Last edit: by Nessism.
Cylinder scoring 10 Feb 2024 12:35 #895091
  • stinkfinger
When I assembled the engine, I wiped down the bore with a light coating of non-synthetic 30 weight.  I don’t think that I lubricated the pistons separately.  I’m using some inexpensive 10w-40 dino oil in the engine for break in.
Last edit: by stinkfinger. Reason: Fixed images
Cylinder scoring 10 Feb 2024 12:47 #895092
  • stinkfinger
Does this amount of movement/clearance seem normal?
IMG_7607.mov
Cylinder scoring 10 Feb 2024 12:48 #895093
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 659
Did you check and adjust ring end gap?
Z1000J2 somewhat modified!
Cylinder scoring 10 Feb 2024 12:53 #895094
  • stinkfinger
Ring gaps were measured, all were on the loose side.  I read somewhere “if your end gaps are too loose, only you will know.  If they are too tight everyone will know”.  This is what I measured:
Cylinder scoring 10 Feb 2024 14:30 #895099
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1816
That looks like the result of a "dry start" using such a light oil probably means that most of it had run off before first start. If the scuffs are only visible but you can't feel them with your finger nail chances are you will be OK. I always use "assembly paste" as it doesn't run off so does it's job until the oil is circulating enough to wash the paste out.
The following user(s) said Thank You: daveo, sf4t7
Cylinder scoring 10 Feb 2024 19:15 #895108
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Wookie58
How much and when do you apply the Graphogen paste to the piston skirts?
1982 KZ1100-A2
Cylinder scoring 10 Feb 2024 20:47 #895113
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
Last edit: by blipco.
Cylinder scoring 11 Feb 2024 01:12 #895115
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Wookie58
Expect to pay around $40 for a 125g tube (there is also a 50g tube) I wipe it onto cam bearings, crank bearings, cam Lobes etc. With my finger and use a paint brush to apply it to pistons prior to installing them in the block. If you are putting "the block onto the pistons" (I put them in the block first as working alone I find it easier without damaging rings) paint the graphogen in the bores rather than on the pistons.
Last edit: by Wookie58.
Cylinder scoring 11 Feb 2024 09:56 #895122
  • daveo
  • daveo's Avatar
  • Premium Member
The Graphogen must then coat everything as it dissolves and circulates through the motor...
Are certain oil change procedures recommended during and after engine break in?
1982 KZ1100-A2
Cylinder scoring 11 Feb 2024 10:15 #895123
  • Wookie58
  • Wookie58's Avatar
  • Moderator
I will leave that one for the guys much more familiar with these motors
  • Page:
  • 1
  • 2
