  • Page:
  • 1
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 02:49 #894932
  • Robby2894
  • Robby2894's Avatar Topic Author
  • Thank you received: 7
Hello I was wondering if the '91 zephyr 750 engine is the same up to '95? I need a starter motor and was wondering if a 1992 zr750 starter motor would bolt right in and if it has the correct size Bendix with the correct amount of teeth?
What engines and years would have a compatible starter motor with the correct Bendix that would bolt right on?
I can't find just the Bendix for sale anywhere and am going to have to order a whole starter motor, and there is one from a 1992 for a fraction of the price...
Or preferably does anyone have the starter Bendix they'd want to sell? My starter motor is fine and would rather not order a whole starter motor replacement for over $200 just because my Bendix which would cost a fraction of the price is grinded down.
Thanks in advance.
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 05:27 #894934
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2073
You can see which models used the same starter on the Fitment list at Partzilla.
www.partzilla.com/product/kawasaki/21163...33dc43f6d0c98b8e0c65
I do not know exactly what you mean by the Bendix, but all of the individual parts were once available, many still are.
www.partzilla.com/catalog/kawasaki/motor...750-c1/starter-motor
Last edit: by TexasKZ.
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 07:01 #894938
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2680
You might want to check Stockers.  They sell rebuilt starters and rebuild kits.  A good source.
The following user(s) said Thank You: Robby2894
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 07:14 #894939
  • Robby2894
@TexasKZ im referring to the gear on the starter.. sadly they don't manufacture them anymore so no parts store has them in stock.
Last edit: by Robby2894.
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 08:20 #894940
  • Robby2894
it's called the starter motor drive pinion at least in the Chilton manual.
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 08:37 #894942
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 373
Not sure if this will be of help or not.  cmsnl shows they have it at least it does not show it as not available.  They also show a newer/superseeded version of the same part
www.cmsnl.com/products/pinionstarter_21053004/
www.cmsnl.com/products/gear-spur-starter_590511401/
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 11:50 #894945
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1814
Hi Robby, not trying to be a "smart ass" but these starters don't have a "Bendix" (the helical gear on a car starter that throws the starter into engagement with the flywheel) these are permanently engaged hence the need for a "starter clutch"
The following user(s) said Thank You: Nessism, TexasKZ, Robby2894
Last edit: by Wookie58.
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 15:17 #894956
  • TexasKZ
  • TexasKZ's Avatar
Different models and years starter motor compatibility for 91 zr750c1 07 Feb 2024 17:23 #894964
  • Robby2894
Oh man your awesome thank you haha. I couldn't find that gear anywhere and it says they have them in stock... Hopefully on the first of next month when I can afford to order one they will still have them. Thank you
  • Page:
  • 1
