Tachometer end gear.
- Degtyarev
31 Jan 2024 08:58 - 31 Jan 2024 09:02
Hey guys, its my second post on this forum, im still restoring my kz1000 so i cant post any pic of it yet...
But wanted to ask for some help with the tacho gear.
My bike came without it, and since im in argentina... buying it from ebay isnt an option.
To the grain, if anyone can hel me with the following measures i will be gratefull.
I need lenght and diameter for the A, B, C, and D parts, also number of teeth.
Any other measure you can take is welcome by eg. teeth height (adenum), tooth width, depth of the teeth, teeth offset between the two ends, etc.
Btw it looks like the adenum its just c heigt - d height.
So i can replicate it on a lathe.
Thanks in advance.
Thanks in advance.
Last edit: 31 Jan 2024 09:02 by Degtyarev.
- Cra-z1
Re: Tachometer end gear.
31 Jan 2024 10:28 - 31 Jan 2024 10:29
They can be purchased. But not sure what your resources are down there. Retro on eBay may be able to ship to you. Wouldn't that gear be hard to duplicate oil a lath. It has a slight curve to it. It's a worm gear.
Last edit: 31 Jan 2024 10:29 by Cra-z1.
- Degtyarev
07 Feb 2024 05:48 - 07 Feb 2024 05:49
Hey, thanks for the answer..
Btw resources are not a problem, the problem is our customs in Argentina( "aduana" in spanish) who love to lose things, even more... small things, or directly doesnt deliver it at all to his owner.
Last edit: 07 Feb 2024 05:49 by Degtyarev.
- Warren3200gt
07 Feb 2024 06:28 - 07 Feb 2024 06:38
Let me get hold of a mate of mine who lives in Argentina. He has access to a huge stock of NOS kawasaki parts located within your borders.
I will need to advise him the exact part number of how it would have been supplied by Kawasaki (possibly the whole unit) as a spare part in the 70's so he can check his parts list inventory.
It looks to be 13223-011 and seems to be used on all mechanical drive tacho models.
Last edit: 07 Feb 2024 06:38 by Warren3200gt.
The following user(s) said Thank You: Degtyarev
- Degtyarev
15 May 2024 19:05
Hey warren, thanks for your answer and sorry for the delay...
yes, the part is the 13223-011
Named "gear tachometer, 10t" on megazip.
- Degtyarev
- Knobby33
24 Oct 2024 04:07
It seems there are 2 types of gears used. This is from my 76 900. Hope this helps:
1976 KZ900A Diamond Dark Green
Working on restoring to as near as original as possible
2002 CB900F (919)
2002 CB900F (919)
- Injected
24 Oct 2024 09:30I don't understand why you would need to make it since it is still available to order from a Kawasaki dealer or new/used on Ebay.So i can replicate it on a lathe.
That PN fits KZ650/900/1000/1300 so you could narrow down the search on line or at a local motorcycle salvage yard.
1978 KZ650B2 modified project
- H1Vindicator
26 Oct 2024 05:33
The part might not be available in Argentina and their delivery systems apparently can't be trusted.
