Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 11:05 #893198
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
There is no drilling involved, just tapping with the Time Sert tooling provided.
Definantly want the valves closed in the cylinder you are working on.
You got to keep the valves and piston completely out of the line of fire!
1982 KZ1100-A2
The following user(s) said Thank You: Warren3200gt, Robby2894
Last edit: by daveo.
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 11:09 #893199
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Thank you received: 1972
I just can't resist.Ask the King of cobblers
What would Gepetto do ?
Or Tarzans pal Cheeta with his tool of choice to fix anything
The following user(s) said Thank You: slmjim+Z1BEBE, sf4t7, Wookie58, Robby2894
Last edit: by Street Fighter LTD.
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 11:22 #893200
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Thank you received: 113
Yep have to measure first how deep the tap need to go so not hitting the valve.
The following user(s) said Thank You: Robby2894
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 11:35 #893201
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2679
Spark plug threads are repairable in place.  Not the best choice for a bike that you want to lovingly maintain, but doable on a beater.
Grease the tap, to catch as many chips as possible.  You can also attach a hose on a shop vac, to chase any chips that fall off.  And besides, a few aluminum chips shouldn't hurt the engine anyway.
For such a bike, I wouldn't spend the money on an expensive Timesert kit.  Amazon sells cheap china solid insert kits for $20.  No sense throwing good money away on a bike you are going to run into the ground...
The following user(s) said Thank You: slmjim+Z1BEBE, ronnieV, Rolf1976_KZ900, Robby2894
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 12:36 #893203
  • Rolf1976_KZ900
Just tested if it is possible to have the exhaust valve open and if it is not 100% open it should work to use a vacumcleaner in the exhaustport.If you use compressed air when finished in the plughole combined with the vacum in exhaust it should work 99%.
The following user(s) said Thank You: howardhb, Robby2894
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 12:50 #893204
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1027
It's just my opinion, but....
If you're going to do the job....do it right.  The condition of the engine should have little bearing on the quality of the repair.  Do the work as if you were a future purchaser admiring  the work done in the past.  That's what I try to do.
And no...I've never made money selling a bike that I bought to repair.
The following user(s) said Thank You: slmjim+Z1BEBE, daveo, sf4t7, Warren3200gt, Wookie58, Rolf1976_KZ900, Robby2894
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 12:54 #893205
  • Robby2894
  • Robby2894's Avatar Topic Author
  • Thank you received: 7
I know they are. I have decide to not invest anymore money or tine into this bike. Just did the first oil change since I've had it since I haven't really be riding it and it hasn't been running until recently and was just sitting around. I knew it's been dripping oil very very slowly but I found out why. The God damn oil drain hole is stripped exactly like the sparkplug holes and the oil drain bolt won't tighten. So I don't think I will be doing much more to it. Might try to save up for a few months and order a whole new engine, or I might just try and sell it, and make a bit of the money I've put into it back in my pocket. Time will tell.
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 12:54 #893206
  • daveo
  • daveo's Avatar
  • Premium Member
Buy the best for the least used on ebay, and buy American Made.
Then flip it!  You might get all your money back when the job is done, and someone else will benefit as well.
Call Nick:
These threads are perfect, but are easily made much better...
1982 KZ1100-A2
The following user(s) said Thank You: Rolf1976_KZ900, Robby2894
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 12:57 #893207
  • Robby2894
True and with how shits been going with it I don't want to spend that type of money on it anyways haha.
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 13:00 #893208
  • Robby2894
Don't want to make money on it I just want to get a little back. I bought it for 500 bucks bought some stuff for it and have put a little of my time into it. I know I'm not gunna make money from it haha I knew that when I bought it. It's just pissing me of and I feel like the guy that sold it to me ripped me off pretty good.
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 13:04 #893209
  • Robby2894
Like Nessim said a few aluminum chips isn't going to hurt it anyways. Aluminum is way softer than the pistons and the cylinders. It would just spit it out.
Sad day when the bike you picked up has stripped sparkplug holes(91 zephyr750) 28 Dec 2023 13:04 #893210
  • daveo
  • daveo's Avatar
  • Premium Member
There's a butt load of 750 oil pans on ebay, if you don't mind doin a little gasket scraping...
But since it's a Zephyr, I'm a little less sure on that.
Good luck with your project, and remember these old Kaws love every bit of attention they can get!
Give what it wants, and you will be rewarded.
1982 KZ1100-A2
The following user(s) said Thank You: SWest, Robby2894
