  • Page:
  • 1
Engine paint removal 12 Dec 2023 13:15 #892659
  • ronnieV
  • ronnieV's Avatar Topic Author
  • Thank you received: 293
Hey guys,anyone have a trick for removing engine paint without tearing it down? I have a low mileage engine that was painted black.Is there a safe chemical for this or is there a paint that is close to the aluminum color? The motor is out of the frame.
Engine paint removal 12 Dec 2023 14:21 #892664
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 656
This was painted black, a combination of good paint stripper, scotchbrite, a dremel wirebrush, and elbow grease did the trick. Not gonna pretend it was quick or exciting to do but the results speak for themselves I think.
Z1000J2 somewhat modified!
The following user(s) said Thank You: ronnieV, Street Fighter LTD, cb900f, Mikaw, Dragbike_Mike, howardhb, Wookie58, Rolf1976_KZ900
Last edit: by Warren3200gt.
Engine paint removal 12 Dec 2023 15:51 #892677
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
I would pull the engine apart and vapour blast the parts.
The following user(s) said Thank You: slmjim+Z1BEBE, ronnieV, Nessism, Street Fighter LTD, Wookie58, Rolf1976_KZ900
Engine paint removal 12 Dec 2023 16:18 #892679
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
The time required to pull that off had to be extensive. We’re not worthy!!!
The following user(s) said Thank You: ronnieV, Nessism, Warren3200gt, howardhb, Wookie58, Rolf1976_KZ900
Engine paint removal 12 Dec 2023 18:47 #892682
  • Mikaw
  • Mikaw's Avatar
I’ve had ok success with the two on the left. Will be trying the rustoleum next. Waiting for 2 sets of hand controls to come back from vapor balst. They are just blasting the inside to remove rust and corrosion. I’m going to chemically strip the outside to help preserve the letters.
The following user(s) said Thank You: ronnieV, sf4t7
Engine paint removal 13 Dec 2023 07:16 #892692
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 600
That's a tall order.
If you're intent on stripping without disassembly, drive rubber stoppers, NOT wood corks, very firmly into intake & exhaust ports.  Junk spark plugs in the plug holes.  Do both regardless of method chosen.
Chemical - Aircraft Stripper.  Do it outside, wear hazmat gloves & eye pro.  Use a stand at working level, so you're not on hands & knees.  Take your time;  It's gonna take days, multiple brass toothbrushes, some Q-tips & flux brushes. And some cussin'.
If you can take it to a commercial surface prep operation, do soda blast.  It won't change the surface appearance of the bare aluminum significantly, but must be neutralized afterward.  Next best media would be crushed nut shell; takes longer $$.  Dry crushed glass will leave a more polished finish.  Sand blast will leave a very dull finish.
Honda used silver motor paint on some bikes, but we don't know anything about it.  Surface prep would be very critical.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: by slmjim+Z1BEBE.
Engine paint removal 13 Dec 2023 09:36 #892697
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1623
Valve cover as purchased.
After. used Jasco premium paint & epoxy stripper from Lowes. not sure if the product is still available. It's been more than a few years.
Then dremel w jeweler's brass wire wheels. needs more work. I didn't try polishing it w mothers or anything which might be all it needs.
It doesn't look anywhere near as good as the pic Mikaw posted. It was a lot of work.
Last edit: by martin_csr.
Engine paint removal 26 Mar 2024 08:06 #896901
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
I stripped my engine cases down and this stuff did an OK job  Citri Strip
It helps to wrap it up in something. I used a large trash bag and let it sit overnight. Then I took my pressure washer to it.
It took some time but did a decent job.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Engine paint removal 26 Mar 2024 14:02 #896920
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 85
Looks good. No matter what you use it can be a messy job. Are you going to have it vapor blasted now?
Engine paint removal 26 Mar 2024 17:51 #896938
  • slmjim+Z1BEBE
Was that the OEM motor paint?
Good Ridfn'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Engine paint removal 27 Mar 2024 05:08 #896949
  • ThatGPzGuy
No. It's a GPz so it is getting the black treatment.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Engine paint removal 27 Mar 2024 05:09 #896950
  • ThatGPzGuy
Good Ridfn'
slmjim & Z1BEBE
Yes, plus some additional engine paint over the years.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Page:
  • 1
