Is this the correct cam timing for TDC? 1978 KZ400B.
- NoahTaylor98
16 Nov 2023 04:19
Can anyone confirm or correct my timing here? I think i have it correct but wanted to double check.
- NoahTaylor98
Re: Is this the correct cam timing for TDC? 1978 KZ400B.
16 Nov 2023 04:23
Images are attached above. I also uploaded them to an image sharing site just in case they wont open in the above post. here are the links.
i.postimg.cc/7bvfhBzQ/20231116-065351-HDR.jpg
i.postimg.cc/nrmq39Yg/20231116-065408-HDR.jpg
- Michel3007
16 Nov 2023 04:45
If your crankshaft is indeed at TDC, then you are good to go.
Double-check that, making sure that you pull the chain taut before rotating the crankshaft.
Here are the manual pages in case you need them.
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
16 Nov 2023 19:40
To make the picture load full size, be sure to click the Insert All button.
