Oil drain plug o ring?
  • Brmercado
  • Brmercado's Avatar Topic Author
19 Oct 2023 04:57
#890641
Hello everyone, to start I have a 81 kz440d1 belt and am curious if it has an oil drain plug o ring and or o ring for the oil filter, I know other kzs with my engine size have them but when doing my first oil change there was only a gasket for the oil filter and a washer for the oil drain plug. Is this normal? Or should it be sealed? Pic for reference
  • Nessism
  • Nessism's Avatar
  • Away
Re: Oil drain plug o ring?
19 Oct 2023 05:07
#890642
There is an O-ring for the oil filter cover, and a sealing crush washer for the drain plug.
You can look up this info in the parts fishe here... www.partzilla.com/catalog/kawasaki/motorcycle/1981/ltd-kz440-a2
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
19 Oct 2023 05:17
#890644
All info is available on CMNSL or Partzilla websites
