  • Page:
  • 1
Driven Cam Damper 06 Oct 2023 10:27 #890155
  • Youngblood
  • Youngblood's Avatar Topic Author
  • Thank you received: 4
Ok been reading a lot about the transmission today and found a driven cam damper attached to the gearbox is this to smooth out the shaft drive??
Sorry this on a Z1300 engine
Last edit: by Youngblood.
Driven Cam Damper 09 Oct 2023 02:26 #890247
  • Youngblood
My suspicions where correct the Z1300 has a damper on the end of the driven shaft and in the gearbox to smooth out gear changes and shaft drive, so if the drive shaft train is removed there will be no need for this part as well making it a whole lot easier for my conversion.
Driven Cam Damper 09 Oct 2023 04:23 #890249
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2074
Yes, they are to dampen vibration and harshness, which is why chain drive bikes have a damper in the rear wheel.
Driven Cam Damper 09 Oct 2023 05:16 #890250
  • Youngblood
Correct
  • Page:
  • 1
