  • Page:
  • 1
  • 2
Fitting Ignition to a GPZ1100 84=85 motor 26 Sep 2023 01:41 #889769
  • Bozo
  • Bozo's Avatar Topic Author
  • Ride it like u stole it
  • Thank you received: 104
I searched this forum but couldn't find details of using Ignition on a GPZ1100 84 -85 Unitrack Kawasaki.
I will be using carburetors (Injection totally removed) can I use the standard ignition module and timing pickups at the end of the crank (if so how does the advance work) or is there a Dyna ignition system that fits. I know the points/ ignition cover is different to the earlier models.
Third ride is now the Frankenstein 1981 GPZ1100B1, getting new/ refurbished 83-84 motor soon
Forth my work bike FJ1200 1989 (same type as above)
Fitting Ignition to a GPZ1100 84=85 motor 26 Sep 2023 02:30 #889770
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1814
I am planning to fit an A2 ignition module, pick ups and end housing to my 1000K. The ignition is standalone (I believe the module is 21119-1071) The advance curve is fully electronic and is mapped in the control module (see thread "retrofit ignition")
Retrofit ignition - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
Last edit: by Wookie58.
Fitting Ignition to a GPZ1100 84=85 motor 26 Sep 2023 03:11 #889772
  • Bozo
Thankyou for your input, correct me if I'm wrong. I should be able to re-use the electronic ignition from my GPZ1100 83-85 and the pickups with the standard timing plate fitted to end of the crank. The electronic timing curve is regulated as revs increase (by the ignition module)
Fitting Ignition to a GPZ1100 84=85 motor 26 Sep 2023 03:36 #889773
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Correct
The following user(s) said Thank You: Bozo
Fitting Ignition to a GPZ1100 84=85 motor 26 Sep 2023 05:21 #889777
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1973
Good to see you posting Bozo !!!!
Fitting Ignition to a GPZ1100 84=85 motor 26 Sep 2023 17:13 #889812
  • Bozo
Thankyou, I suppose my bikes have been going too well to consult / read the posts.
I now have a GPZ1100 83 unitrack motor which has been totally rebuilt (just the head to finish next week). I want to replace the standard as new GPZ1100B1 motor in my Franken bike (with 83 cams), this motor develops 95RWH BUT I always wanted the 83 so when a good engine was advertised I bought it,
Last edit: by Street Fighter LTD.
Fitting Ignition to a GPZ1100 84=85 motor 26 Sep 2023 23:43 #889816
  • Wookie58
  • Wookie58's Avatar
  • Moderator
That 1100 is really nice Bozo
Fitting Ignition to a GPZ1100 84=85 motor 27 Sep 2023 11:50 #889839
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Agreed 1000%
Would it make sense to install J-head valve components (springs, retainers, buckets, etc) into the ZX1100A head to simplify lash adjustments, comparatively speaking?
1982 KZ1100-A2
Last edit: by daveo.
Fitting Ignition to a GPZ1100 84=85 motor 27 Sep 2023 12:31 #889840
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Agreed 1000%
As I understand it the "J"head isn't compatible with the pistons used in the later motor ??
Fitting Ignition to a GPZ1100 84=85 motor 27 Sep 2023 12:52 #889841
  • daveo
  • daveo's Avatar
  • Premium Member
Agreed 1000%
Correct, not the head, just the valve components...
Easily change shims without removing the camshafts, comparatively speaking of course.
1982 KZ1100-A2
The following user(s) said Thank You: Bozo, Wookie58
Fitting Ignition to a GPZ1100 84=85 motor 28 Sep 2023 04:19 #889861
  • Bozo
That 1100 is really nice Bozo  Thanks again. This particular engine has a J model head, I did clean up the porting. Cams are GPZ1100 83 Unitrack model. Would you believe there are around 17 different motorcycle bits used hence Frankenstein,CBR1000F wheels, speedhut gauges, zx10 clutch lever, ZRX1100 carbies, GTR1400 radial master brake, EX650 brakes (new addition re welded brackets), GPZ900R Front end, GPZ750 turbo swingarm, ZX750R Bitubo Shock (this bike weights 215kg with fuel), marving race pipe plus many more.Handles and goes incredible BUT I still want the GPZ1100 83 Unitrack motor
Daveo, that motor in your picture is Fantastic Porn
The following user(s) said Thank You: daveo, Wookie58
Last edit: by Bozo.
Fitting Ignition to a GPZ1100 84=85 motor 28 Sep 2023 05:04 #889862
  • Wookie58
  • Wookie58's Avatar
  • Moderator
I can easily believe the "donor" list. Don't know if you have seen my build thread but I will end up at a similar number of donors I think
  • Page:
  • 1
  • 2
