Heli-coil kit for stripped spark plug hole
- daveo
Re: Heli-coil kit for stripped spark plug hole
13 Sep 2023 11:31 - 13 Sep 2023 12:30
1982 KZ1100-A2
Last edit: 13 Sep 2023 12:30 by daveo.
- Kelly E
13 Sep 2023 12:03
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- daveo
13 Sep 2023 12:11 - 13 Sep 2023 12:28Had to use my wife's laptop to do it.
Probably not a good idea to copy/paste images from past forum posts...which is what I initially did.
Whew!
1982 KZ1100-A2
Last edit: 13 Sep 2023 12:28 by daveo.
13 Sep 2023 12:38
13 Sep 2023 13:37
- daveo
13 Sep 2023 14:26 - 13 Sep 2023 18:23
Steve, I reposted the image from my phone after attempting to copy/paste it from a previous KZR post on the subject. That method produced a mile of illegible code that took several edit attempts to delete.
1982 KZ1100-A2
Last edit: 13 Sep 2023 18:23 by daveo.
13 Sep 2023 14:45
13 Sep 2023 15:00
Maybe it doesn't matter, but Timeserts are thicker and have more mass than a small insert like a helicoil. I've read that they can affect heat transfer through the plug. They sell aluminum Timeserts, and I wonder if those would be a better option for an air cooled motorcycle?
The following user(s) said Thank You: sf4t7, howardhb
13 Sep 2023 16:20An interesting point Ed but I would come back to my original question, the OP said the 14mm coil was way to big and to be honest in the picture at least, that looks like a 12mm plug next to the 14mm coil to me. If that is the case it's no wonder it blew outMaybe it doesn't matter, but Timeserts are thicker and have more mass than a small insert like a helicoil. I've read that they can affect heat transfer through the plug. They sell aluminum Timeserts, and I wonder if those would be a better option for an air cooled motorcycle?
- daveo
- Gdailey2112
- 82 KZ1100D1
17 Sep 2023 19:10
Went with a NAPA-sert and a tap, so far so good!! Much thanks!
1982 KZ1100D1
- gordone
22 Sep 2023 15:33 - 22 Sep 2023 15:33
I repaired with wurth many years ago works perfect sinceā¦
eshop.wurth.co.uk/Product-categories/Spa...3108.cgid/en/GB/GBP/
wurth timeinsert is using High thermal conductivityCopper coating
Project:
Project:
Last edit: 22 Sep 2023 15:33 by gordone.
