  • Page:
  • 1
  • 2
KZ400H Oil Seal Kit Alternatives? 09 Sep 2023 09:43 #889196
  • Dr. Frankenstein
  • Dr. Frankenstein's Avatar Topic Author
  • Thank you received: 19
I fired up my '79 KZ400H today for the first time since I don't know when, and nothing can show you problems like a dynamic test! I have an oil leak from my crankshaft oil seal and discovered that there are scant oil seal kits out there for the KZ400/KZ440...or am I just looking in the wrong place? Is there another oil seal kit that works/fits (Yamaha, Suzuki, Honda, etc), or by-the-piece oil seal that works? Does anybody know what size that seal is?
KZ400H Oil Seal Kit Alternatives? 09 Sep 2023 10:08 #889198
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
eBay has seals
PN 92050-065
KZ400H Oil Seal Kit Alternatives? 09 Sep 2023 14:29 #889207
  • Dr. Frankenstein
Yes, they do - for $25 apiece. I'll see what number is on the seal itself, try to reference the size that way. They're usually waay cheaper if you get the seal number off of it and get an identical one from Seals-R-Us or someplace. I just have to drain the oil, take the points and advancer off, take off the side cover, replace the seal, replace the side cover, put the advancer back in, then the points, and re-time the bike. Again. Piece of cake.
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 08:24 #889250
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
Any Industrial Supply. Even Amazon. Pop it out. measure the O.D. x I.D. x thickness. in mm's. Don't waste time looking for #'s
40 x 25 x 7 mm's
I use Buffalo Bearings Local. Because of me, Greg stocks All Balls Z1/KZ items. He was the 1st dealer distributor for All Balls items
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 12:14 #889258
  • Dr. Frankenstein
Yup, I just got three of them for $9 on Amazon:
uxcell Oil Seal, TC 25mm x 40mm x 7mm Nitrile Rubber Cover Double Lip with Spring for Mechanical Motive Axle Shaft, Black Pack of 3: Amazon.com: Industrial & Scientific
Of course, they don't have that nifty Kawasaki logo on them like the $25 dollar one on Ebay...I guess I will Just Have to Manage...!
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 15:22 #889272
  • Nessism
  • Nessism's Avatar
40 x 25 x 7 mm's
How did you come up with the seal size?  Did you pull an old seal out of a cover and measure it?
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 16:13 #889274
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1825
40 x 25 x 7 mm's
Generally speaking the number on the seal ( not the OE part number) is the ID-OD-depth
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 16:31 #889276
  • Nessism
  • Nessism's Avatar
Looking at photos on ebay of seals, I don't see any numbers.  The Kawasaki label DOES provide this info, though.  That's nice!
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 16:47 #889277
  • Dr. Frankenstein
Knowledge gleaned from years of rebuilding bikes. Looking at pics of a seal won't do you any good, you have to hold it in your hand. A magnifying glass helps. The part number is great if you have it, but if you look closely at any seal, it has a number on it, f'rinstance 25 40 7.  In this case it's 25mm ID, 40MM OD, and 7mm thick. And yes, I did take it out and look at it. Like I said, it doesn't have that nifty 'Kawaski KZ400" logo on it - but I don't think the shaft cares.
Last edit: by Dr. Frankenstein.
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 19:51 #889279
  • z1kzonly
  • z1kzonly's Avatar
eBay has seals
PN 92050-065
Ed! I used your information.  a few clicks? Had the size.
I have no clue?  Don't need or whatever.
Was just  passing by
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 19:57 #889280
  • z1kzonly
  • z1kzonly's Avatar
I was just there to get a M #206 bearing! So common in Industry.
62mm x 30mm x 16.  (2 0 6 )
I went for a 76 KZ900 LTD rear carrier.
Cash account $9.79.
Just Cruisin" thru the threads here?
Anyone need an LTD - 1976 Only, Morris Mag?
  [/attachment]
Last edit: by z1kzonly.
KZ400H Oil Seal Kit Alternatives? 11 Sep 2023 20:05 #889281
  • z1kzonly
  • z1kzonly's Avatar
I know this rear is limited to the this 1 bike.
But, when listed? For the Kawasaki LTD? If no interest?
I will strip the Kaw stuff off and sell the 2 blank rims to the Harley People.
That sure are nice!
  • Page:
  • 1
  • 2
