- Thank you received: 35
Got a quest for "how to" (compression related)
- Gdailey2112
- 82 KZ1100D1
19 Aug 2023 16:40 #888506
by Gdailey2112
1982 KZ1100D1
Got a quest for "how to" (compression related) was created by Gdailey2112
Searched hi and low, but what is the correct method of compression testing? My understanding is to remove all plugs, hook compression gauge to cyl testing, hold at WOT while cranking over for 6 revolutions. Not sure if correct, if not please holla
1982 KZ1100D1
- Thank you received: 1089
19 Aug 2023 16:46 #888507
by hardrockminer
Replied by hardrockminer on topic Got a quest for "how to" (compression related)
That's how I do it but I crank the engine until the gauge reaches max.
The following user(s) said Thank You: Warren3200gt, Gdailey2112, Wookie58
- Thank you received: 2817
20 Aug 2023 08:00 #888521
by Nessism
Replied by Nessism on topic Got a quest for "how to" (compression related)
The engine needs to be hot. And if the bike has been out of action for some time, there may be some residual crud on the valves and seats that needs to be burned off with an Italian tuneup. Also, the valves need to be properly adjusted. A LOT of neglectful users don't adjust valves, and with mileage the clearance closes down until the valves don't close anymore, thus leading to compression leak down.
- Thank you received: 2232
20 Aug 2023 12:09 #888526
by TexasKZ
Replied by TexasKZ on topic Got a quest for "how to" (compression related)
I think three or four revolutions is usually enough to get the maximum reading.
- Gdailey2112
- 82 KZ1100D1
21 Aug 2023 16:46 #888574
by Gdailey2112
1982 KZ1100D1
Replied by Gdailey2112 on topic Got a quest for "how to" (compression related)
10-4 thank you
1982 KZ1100D1
