Got a quest for "how to" (compression related)
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
19 Aug 2023 16:40
#888506
Searched hi and low, but what is the correct method of compression testing? My understanding is to remove all plugs, hook compression gauge to cyl testing, hold at WOT while cranking over for 6 revolutions. Not sure if correct, if not please holla
1982 KZ1100D1
  • hardrockminer
  • hardrockminer's Avatar
Re: Got a quest for "how to" (compression related)
19 Aug 2023 16:46
#888507
That's how I do it but I crank the engine until the gauge reaches max.
The following user(s) said Thank You: Warren3200gt, Gdailey2112, Wookie58
  • Nessism
  • Nessism's Avatar
20 Aug 2023 08:00
#888521
The engine needs to be hot.  And if the bike has been out of action for some time, there may be some residual crud on the valves and seats that needs to be burned off with an Italian tuneup.  Also, the valves need to be properly adjusted.  A LOT of neglectful users don't adjust valves, and with mileage the clearance closes down until the valves don't close anymore, thus leading to compression leak down.
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
20 Aug 2023 12:09
#888526
I think three or four revolutions is usually enough to get the maximum reading.
  • Gdailey2112
  • 82 KZ1100D1
21 Aug 2023 16:46
#888574
10-4 thank you
1982 KZ1100D1
  • dewy0823
  • dewy0823's Avatar
12 Nov 2026 08:08
#929059
New to this post, my '82 KZ650 CSR shown in my post "stopping gasket leaks" is likely leaking oil from the head and cyl. block gaskets. The bike has 9800 actual miles and has been ridden about 400 miles since I resurrected it Mar-Apr 2025 by total carb clean/tune/sync, plus usual maintenance and physical cleaning. Nothing is coming from the valve cover or half moon plugs. I tested the compression like this: warm engine, gas tank and carb bowls empty, fully charged 1 yr old battery, all plugs out, choke pulled out (I may have made a mistake here since tech manual says "completely open"), throttle held wide open, crank a few seconds until highest pressure. Cylinders are 1: 104 psi, 2: 110, 3: 93, 4: 105, which is way low. The manual says 170 psi +/- 15 psi. When I warmed it up by riding for 15 minutes on the street, it rain well. I think it's running hot since the exhaust pipes turned slightly blue. I understand a leaking head gasket can cause this. I'll try to test my new compression tester with a known pressure.
1. By pulling the choke out, thereby closing the intake, is this a mistake and would affect the results greatly?
2. Do I need to test the pressure again with cold engine and skirt some 10W40 oil in each cylinder?
Thx
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
12 Nov 2026 08:15
#929060
Repeat the test with the choke open. Then if the numbers are still low add a bit of oil and repeat.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • bound
  • bound's Avatar
  • If you ain't HURTIN' you ain't LEARNIN'!!
12 Nov 2026 10:11
#929065
Your carburetors should have a fuel enrichener circuit which they call a choke. An actual choke has its own butterfly valves on the airbox side of the carbs. The fuel enrichener circuit doesnt affect air volume to the engine so holding the throttle open should be your only worry. Another thing that affects compression is valve clearances. At 9800 miles it is totally possible that no one has done them yet. Finally, make sure that your compression tester is not at fault!!! If all of these are good, do what Kelly said and add oil to the cylinders. If compression dramatically increases, then you may want to replace the rings when doing your gaskets.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
  • Nessism
  • Nessism's Avatar
12 Nov 2026 11:26
#929070
Agree about the valves.  They must be checked regularly because the clearance decreases with mileage, and eventually the clearance will be gone, and then not only does the compression go down, the valves burn.
On a low mileage bike like this, the rings may also be somewhat stuck from inactivity.  I'd adjust the valves as needed, then put a good 500 miles of hard riding on the bike, then check both the valves and compression again.
  • asphalt900
  • asphalt900's Avatar
13 Nov 2026 04:12
#929079
Those old analog "compression" testers can often give erroneous and incorrect readings. The better would be use of a leakdown testing procedure. This will tell you Much more like blown head gaskets/ill-seating valves/bad ring sealing.
