  • Page:
  • 1
KZ400 Air Cleaner Filter Element Thickness? 18 Aug 2023 19:48 #888470
  • Dr. Frankenstein
  • Dr. Frankenstein's Avatar Topic Author
  • Thank you received: 19
Strange question, but can anybody tell me how thick (MM? Inches??) the foam air cleaner pad is that goes inside the KZ400 air box?  That would be #4 in the attachment...
Last edit: by Dr. Frankenstein.
KZ400 Air Cleaner Filter Element Thickness? 19 Aug 2023 09:21 #888491
  • Michi
  • Michi's Avatar
  • Thank you received: 18
Oh, I guess you're replacing just the filter element then. I did that with a Z200. What I ended up doing was buying the new one, which was thinner and made up of 2 foam densities, and sticking that on. Because I figured it's better to have a new clean thin filter element than an original dirty one. Anyway, the foam on the Z200 one was quite thick - about 10mm IIRC.
KZ440A LTD (1980)
The following user(s) said Thank You: Dr. Frankenstein
KZ400 Air Cleaner Filter Element Thickness? 19 Aug 2023 13:06 #888500
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 141
The fuzzy stuff and foam is 11.5mm.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
KZ400 Air Cleaner Filter Element Thickness? 23 Aug 2023 04:45 #888600
  • Dr. Frankenstein
Thanks guys; actually, I'm surprised it's that thick. I don't have that air cleaner insert so I made my own. Whattya think...?  This is just the prototype, I want to make some adjustments to the final construction. It's measured to fit into the air box like a glove, but I didn't know the thickness of the element filter, I was surprised to see that it's that thick. I was wondering about air flow, and how restrictive it is...
KZ400 Air Cleaner Filter Element Thickness? 23 Aug 2023 07:29 #888603
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2100
Filter holder looks good. As to the air flow, that will depend entirely on the density of tha material used. I have never seen any measurement of the factory foam. I think many folks buy a sheet of foam material from Uni, and cut to fit. Flow should be fine, maybe a little more than stock.
KZ400 Air Cleaner Filter Element Thickness? 23 Aug 2023 08:50 #888608
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 320
I bought a sheet of Uni 5/8" green foam to make a filter for my 84' VF 700S. It's cheap and is enough to make 4 Sabre filters. Factory was 1/2" thick but the 5/8" is working just fine.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
KZ400 Air Cleaner Filter Element Thickness? 24 Aug 2023 14:27 #888674
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1929
Filter mats for kitchen extractor hoods are dirty cheap!
  • Page:
  • 1
