- Thank you received: 20
Joining crankcase halves
- Michi
01 Aug 2023 11:48 #887780
by Michi
KZ440A LTD (1980)
Joining crankcase halves was created by Michi
Hi. I'm putting together my KZ440 engine.
Got the manual and everything. Also have a torque wrench. Here's the deal - I've joined the upper and lower crankcase halves. But my torque wrench isn't really designed for the low kgm bolt specs which are clearly spelt out in the manual for the crankcase bolts. My torque wrench is not accurate on low torques. It starts at 20Nm.
So it's together and it's got Threebond between the halves, and I've got the bolts in (the M6 ones perhaps a little tighter than they should be, but not crazy tight). The big ones (M8) are spot-on. Question is, is this going to cause me problems, or should I buy a low-torque torque wrench, remove the bolts and do them up again. In short, can I get away with this, without leaks and warpage.
KZ440A LTD (1980)
- Thank you received: 2817
01 Aug 2023 12:00 #887781
by Nessism
Replied by Nessism on topic Joining crankcase halves
You should be fine.
The following user(s) said Thank You: Wookie58, Michi
- Thank you received: 1089
02 Aug 2023 04:01 #887798
by hardrockminer
Replied by hardrockminer on topic Joining crankcase halves
It's very easy to over torque an M6 bolt without a torque wrench. If you don't know how tight they are you simply don't know. I don't think the downside is all that serious though. If they didn't snap when you installed them they probably will be OK. You may lose one or two due to fatigue in the future so you might want to check them from time to time. Ultimately though, if you plan to do any more engines you would be well served by having the correct tools.
- Thank you received: 2316
02 Aug 2023 04:30 #887802
by Wookie58
Replied by Wookie58 on topic Joining crankcase halves
Couldn't agree more, to be fair loosening and re-torqueing them may be "the straw to break the camels back" as far as pulling threads out goes !It's very easy to over torque an M6 bolt without a torque wrench. If you don't know how tight they are you simply don't know. I don't think the downside is all that serious though. If they didn't snap when you installed them they probably will be OK. You may lose one or two due to fatigue in the future so you might want to check them from time to time. Ultimately though, if you plan to do any more engines you would be well served by having the correct tools.
The following user(s) said Thank You: Michi
