  • Page:
  • 1
  • 2
APE nuts 27 May 2023 15:56 #885295
  • TerryK
  • TerryK's Avatar Topic Author
  • Thank you received: 2
Hey dumb question: you guys using oversized head studs on 900/1000s, how do you seal the outside four nuts so they don’t piss oil? These are the open top nuts, not the closed ones.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
APE nuts 27 May 2023 16:17 #885297
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2095
They should all be acorn (closed top). The main bearing studs use open nuts.
kzzone.com/studs.html
APE nuts 27 May 2023 20:46 #885307
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2649
I'm using the stock ones with new copper washers.
APE nuts 28 May 2023 07:26 #885320
  • Injected
  • Injected's Avatar
  • Thank you received: 456
I have seen those aftermarket black nuts with the open tops. Those are mostly for drag racing.
Use new copper washers that are tight to the studs and smear some RTV on the threads before torquing them down, you should be OK.
APE nuts 28 May 2023 10:31 #885331
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 94
I use the closed nuts along with the APE cylinder studs. I use new copper washers and spray them with a light coat of Permetex copper spray. For a street bike I would not use the open nuts on the outside studs
APE nuts 29 May 2023 12:35 #885361
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 386
It must be the 11 year old in me, but when I first read the tittle of this topic I first thought of these two pictures before I realized just what the topic was about.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: daveo, sf4t7
APE nuts 29 May 2023 15:21 #885365
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 302
Ha Ha, me too!
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
APE nuts 29 May 2023 23:19 #885384
  • Wookie58
  • Wookie58's Avatar
  • Online
  • Moderator
  • Thank you received: 1916
APE nuts 31 May 2023 19:56 #885516
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
I want a set of removable stainless or chromed steel covers to fit my big black APE stud nuts...
1982 KZ1100-A2
The following user(s) said Thank You: SWest, Wookie58
Last edit: by daveo.
APE nuts 31 May 2023 21:08 #885517
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 265
Ouch !
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
APE nuts 31 May 2023 21:52 #885519
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
Unfortunately MTC doesn't make them anymore. The only cylinder studs I have ever used in my motors were the MTC Golden Studs. They are the exact dimensions of the stock studs but just made of a better metal. I also use copper washers on all 12 studs. If I reused some old ones I always annealed them and made sure they had a smooth surface where the head nuts came in contact with them. On the four outer washers I applied a thin coat of Three Bond TB-1211 on both sides of them. Never used anything but the stock head nuts. Never saw the need for those fancy cylinder head nuts!! Somebody in the late '80's did sell some Titanium copies of the stock head nuts. The price was crazy so I passed on buying them. I always follow the factory torque pattern in the shop manual and I never use more than 31 pounds of head torque. I never suffered any type of head gasket leaks or oil leaking from those outer studs.
1986 RG500G 2 stroke terror.
APE nuts 01 Jun 2023 05:33 #885523
  • Injected
  • Injected's Avatar
The APE nuts/studs are for racing, you can torque them to +45 FT LBS they are for high compression applications. You don't need them for a street bike.
They only offer them in black because racers don't need chrome.
  • Page:
  • 1
  • 2
