#4 plug getting oil fouled
- Polar_Bus
20 May 2023 14:47 - 20 May 2023 17:19
Hey all,
So i'm seeing some unusual oil fouling on the #4 plug on my GPz1100 . About 7500 miles ago I had to have the head's valve guides replaced from a siezed exhaust valve guide. While the engine was disassembled I honed the cylinder and replaced the piston rings. The engine has about 14K total mi currently. This engine has always burned some oil, but never a smoker. I'm suspecting a bad intake valve seal as when the valve is open, I can actually see a lot of oily crud on the backside of the valve face when looking down into the cylinder. My question is has anyone sucessfully changed out a valve seal not having to remove the cylinder head ?
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
Last edit: 20 May 2023 17:19 by Polar_Bus.
- kevinduke
Re: #4 plug getting oil fouled
23 May 2023 20:28 - 24 May 2023 04:31
It indicates oil leakage to the combustion chamber. The main reason is bad piston rings or excess engine oil. Please replace the piston rings and see whether the problem is fixed or not.
Last edit: 24 May 2023 04:31 by Street Fighter LTD.
24 May 2023 07:08
I have read about two methods, but have no personal experience with either of them.
1. Putthe piston a bit below tdc. Thread some small diameter rope (clothesline size) into the cylinder through the spark plug hole. Gently rotate the crank to push the piston upward until you feel resistance. The rope will prevent the valve from dropping while replacing the seal.
2. Put the piston at tdc and install an air hose fitting in the spark plug hole. Set the line pressure fairly low before connecting the hose. Too much pressure will push the piston downward. A little experimenting with pressure before removing the spring might save a bunch of time and frustration.
- Polar_Bus
25 May 2023 17:30I have read about two methods, but have no personal experience with either of them.
I'm familiar with methods to keep the valve from dropping (rope trick) the problem is how do I COMPRESS the bucket in order to remove the stem keepers. There's no special tool to my knowledge.
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
25 May 2023 18:25
Somewhere back in a cobweb infested corner of my memory, I seem to recall a home made rig that used a plate bolted down to the cam cap bolt holes as a fulcrum and a lever with a tube that has a cut away, similar to a regular spring compressor, welded to the lever. The short end of the lever went under the fulcrum plate and the cut away allowed removal of the keepers.
I have heard of folks using a brass rod and a hammer. Place one end of the rod on the retainer and give the other end a sharp whack or two and the keepers supposedly pop out. How it goes back together I have no idea. Seems like a disaster in the making, so if you try this, please make a video recording with sound.
26 May 2023 00:12
26 May 2023 14:41
Could possibly use the other camshaft to hook on.
