RPM crusing
Re: RPM crusing
19 May 2023 14:11 - 19 May 2023 14:12
The part of your post that I quoted above makes me wonder if the tachometer is reading 1000 rpm higher than the engine is actually turning.
Last edit: 19 May 2023 14:12 by TexasKZ.
- gordone
Re: RPM crusing
19 May 2023 14:29understand, no I haven’t.The part of your post that I quoted above makes me wonder if the tachometer is reading 1000 rpm higher than the engine is actually turning.
but when I tune in idle I get on 2200-2300, so maybe that is an indication?
I think there is two parallel thing her.
1. RPM properly showing to much.
2. From listen on the engine sound when crusing in 80-90km/h I feel it should have been 1000 lower… I quite often need to verify I’m in 4th gear and have one more gear
Project:
Project:
Re: RPM crusing
19 May 2023 15:00
With stock camshafts, idle should be around 1100. With high performance camshafts, a little higher, but nowhere near 2000.
- Injected
Re: RPM crusing
19 May 2023 15:34 - 19 May 2023 15:35No wonder your reving 6000 at 90KPH... your already 1100-1200 RPM higher than you should be.understand, no I haven’t.The part of your post that I quoted above makes me wonder if the tachometer is reading 1000 rpm higher than the engine is actually turning.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 19 May 2023 15:35 by Injected. Reason: sp
Re: RPM crusing
20 May 2023 11:12
The stock gearing for your bike is 13/33 for a 2.54 ratio running a 630 chain.
I assume your bike is converted to 530 chain?
Assuming yes, that suggests a 16/40 or 41 sprocket configuration. Since your bike is running a 42 rear sprocket, that means your gearing is lower.
Since you have an 810 kit, with much more torque than stock, you can easily run taller gearing. A 17T front is the easiest change, assuming you have clearance. A double change, including the rear sprocket, is another option. I'd try the 17 front first though.
- gordone
Re: RPM crusing
20 May 2023 14:06 - 20 May 2023 14:09Thank you, 530 chain is correct.The stock gearing for your bike is 13/33 for a 2.54 ratio running a 630 chain.
I haven’t replace anything (replaced all last time) on the chain/sprocket so replace front sprocket is properly good todo anyway do to wear.
normaly I unddrstand there should be space for 17?
Will the gas consume go down on crusing?
Can I reuse the nute and washer?
Project:
Project:
Last edit: 20 May 2023 14:09 by gordone.
- Injected
Re: RPM crusing
20 May 2023 14:32 - 20 May 2023 14:45
There is room for a 17T front running a 530 non O-ring chain so it clears the stock steel front chain guard.
It may rub with a O-ring chain, not sure.
I had to change my gearing because I could not make it across a intersection without lifting the front wheel. Since then this has been my go to gearing for my non stock 650 builds (750 Spectre engine shown)
Last edit: 20 May 2023 14:45 by Injected. Reason: pic
