  • Page:
  • 1
Drive sprocket nut 23 Sep 2021 10:31 #855680
  • nickjones80
  • nickjones80's Avatar Topic Author
  • Thank you received: 0
New to KZrider so forgive me if this has been a topic before.  I tried searching for previous topics on this but nothing came up.
I am trying to remove the drive sprocket nut but am having troubles.  The Clymers manual states to, “have an assistant hold the rear wheel to keep the drive chain taut”.  Unfortunately the engine is not in the bike.
Any other tips or tricks for removing it?
Last edit: by Street Fighter LTD.
Drive sprocket nut 23 Sep 2021 10:47 #855682
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Welcome to KZRider. I fixed your pictures to be full size.  Next time click the insert all tab to complete the installation.
Best to include what bike / motor you are working on  when posting .
   You can use a impact gun to loosen the nut and also wedge the sprocket teeth with a piece of wood being carefull not to alloew the wedge to push against  the rod shown or a edge of the  engine  / trans  casting  ( Just be careful )
 Others will take a old  chain and  secure it over the sprocket  and clamp it so it cant spin  while loosening the nut .
Drive sprocket nut 23 Sep 2021 12:13 #855686
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Check here. Some homemade tools posted by 650ed and Old_kaw
www.kzrider.com/forum/2-engine/611868-79...tuck?start=12#814649
Last edit: by Mikaw.
Drive sprocket nut 23 Sep 2021 16:04 #855703
  • woodyvale
  • woodyvale's Avatar
Some great ideas in the thread from Mikaw.
Follow the advice about using a rattle gun, don't try it with a breaker bar - speaking from bitter experience!
Drive sprocket nut 24 Sep 2021 07:14 #855711
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 600
If the top end, or at least the bottom end is still together it might help to put the trans in 1st. gear when using an impact gun on that nut.  That'll introduce some additional friction & inertial mass to work against.  If it's in neutral the shaft might just spin.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Drive sprocket nut 24 Sep 2021 08:23 #855718
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
It doesn't seem like a good idea to me to put the shock loads from an impact gun through the transmission gears.  I really don't think that would be good for gear teeth.  It's not the type of load they were intended to take.  It think using a chain wrench to hold gear seems like a much a better idea.
My dad's '74 Z1
'00 ZRX1100
Drive sprocket nut 24 Sep 2021 09:31 #855721
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 265
Welcome to KZRider. I fix snip
This is what worked for me.
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
Last edit: by slayer61.
Drive sprocket nut 28 Sep 2021 05:22 #855861
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Sooo what was the outcome here??
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Drive sprocket nut 07 Oct 2021 10:06 #856311
  • nickjones80
What size socket does it need? Clymers doesn’t say.  Still working at getting that nut off.
Drive sprocket nut 07 Oct 2021 12:17 #856323
  • Mikaw
  • Mikaw's Avatar
Measure across the flats of the nut. It will tell you what size socket you need
Drive sprocket nut 08 Oct 2021 12:20 #856378
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 369
It would be of help to know just which engine/model you are working with. If you have posted this and I did not see/find it then I apologize for that. But from the pics/pages you posted it appears to me to be a (k)Z650, but what do I know. With knowing just which model/year we may be able to provide you with the size of the nut as there are some differences in them over the years/models.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Drive sprocket nut 10 Oct 2021 06:13 #856480
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Kawasaki sometimes lists the size.
For example, for the 1977 KZ650
www.kawasaki.com/en-us/owner-center/part...Z650-B1-_-PARTBUCKET
If you are unsure which year and model the engine came from, you may be able to suss it out here.
www.kzrider.com/filebase/download/64-gen...78-kz-by-the-numbers
Last edit: by TexasKZ.
  • Page:
  • 1
