What's the difference between KZ1000 and Z1 clutch covers?
  • Robb2018
  • Robb2018's Avatar Topic Author
  • 76 KZ900 73 Z1 A
07 Jun 2021 05:30 - 07 Jun 2021 05:37
#849726
Seller says it's different than Z1 and KZ900 covers but will still fit. It looks exactly the same to me.
KZ900; Z1
Last edit: 07 Jun 2021 05:37 by Robb2018.
  • krazee1
  • krazee1's Avatar
Re: What's the difference between KZ1000 and Z1 clutch covers?
07 Jun 2021 06:07
#849730
The engine covers got thicker either between the Z1/KZ or the KZ900/KZ1000.  Probably to lessen mechanical noise from within, they will interchange.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
  • zed1015
  • zed1015's Avatar
07 Jun 2021 06:48
#849736
900 and 1000 covers are visually the same and interchange.
As mentioned above, the later covers are thicker for sound deadening.
Only the later MK2 covers are visually different having a raised centre but again they bolt straight on too.
  • Mikaw
  • Mikaw's Avatar
07 Jun 2021 10:11
#849748
No additional comments other than I’d say look inside and see if there might still be remnants of an ink type stamp for a date. I’d keep as many dated items as possible. I’m sure either glass bead or vapor hone would remove the paint and restore the exterior finish.
The following user(s) said Thank You: Robb2018
  • Mikaw
  • Mikaw's Avatar
07 Jun 2021 10:13
#849749
This is a points cover but the clutch cover would have been stamped in the same manor.
  • Mikaw
  • Mikaw's Avatar
07 Jun 2021 10:20
#849750
To be correct the stamp would need to be
47 xx xx. The second xx will be the month and then xx will be day
example, 47 09 10 would be September 10 1972
  • Robb2018
  • 76 KZ900 73 Z1 A
07 Jun 2021 18:12
#849799
The sprocket cover and clutch cover that came with the bike are both in very good shape... but they've been chromed.  I'll check and see if there's a date stamp.  I was thinking about sand blasting the chrome off but I don't have a blast cabinet and have recently discovered how dangerous sand blasting outside in the open air can be... very dangerous fumes that hang in the air for a very long time. I have a feeling neither one is original anyway.  If anyone would like to trade a crappy aluminum sprocket and clutch cover for some really nice chrome ones... I'd be all over that.
KZ900; Z1
  • Mikaw
  • Mikaw's Avatar
07 Jun 2021 19:46 - 07 Jun 2021 19:50
#849800
I thought I saw them as painted. Sorry. The best way to have the chrome is chemically stripped. Basically a reverse of the chrome process. Tripp Plating in Buffalo NY.
Here’s where I pass it off the experts. I’ve seen some Z1 engines with chrome covers. I have a ‘74 engine that they are all chrome. I haven’t found anything in John Brookes book about any covers factory chrome. This is a good time to find that answer.
Edit: If your clutch cover is original to the bike it will have S-1 cast on the inside of the cover. Also will have the ink date stamp
Last edit: 07 Jun 2021 19:50 by Mikaw.
  • hardrockminer
  • hardrockminer's Avatar
07 Jun 2021 20:02
#849801
Engine covers on Z1s were not chrome, although some owners buff them up until they shine like chrome.  Kawasaki was cheap on chrome, which is why you can see striations in chromed wheels.  Also, look on the underside of your brake pedal, or the back side of your torque arm.  Not much chrome there.
Some later bikes had chrome covers.  My B4 has them.
