kz650 1978 Q/A 29 Apr 2021 11:26 #847685
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1903
1. Tensioner question. One from 78, one from 79. Both seem to be in good condition. Should I favor one over other?
2. Seals question. For shift rod Do the installed same orientation, face out? Or they installed back to back?
#1 use the tensioer with the stronger spring. Maybe a manual tensioner mod would be an option..
#2 do install the seal in the same orientation and use a good permanent grease on the shaft agianst wear, moisture and corrosion.
Last edit: by Scirocco.
kz650 1978 Q/A 29 Apr 2021 11:43 #847688
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
For #1 I'd rather not spend money yet if not needed. Is there issue with stock tensioner(s)? Bike is stock, not for racing.
For #2. What was an idea for 2 seals? You propose I do it like pictured (dang I didn't pay attention when disassembled). But to me sounds like #2 should be reversed. This way I can pack it with grease inside. No?
kz650 1978 Q/A 29 Apr 2021 13:01 #847695
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
#1 you don´t need to spend money for the manual tensioner mod only some work to do by your self, pics follows...
#2 as you sketch up, position the seal like that to keep the grease into the shaft bore of the clutch case.
kz650 1978 Q/A 29 Apr 2021 13:13 #847697
  • katit
Problem is - "INSIDE" is not sealed. It's a void where sprocket/etc is. To me makes sense to keep grease between seals.
kz650 1978 Q/A 29 Apr 2021 13:42 #847701
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Yes, you are right but KHI engineers  didn´t thought like you and me but you can put a rubber boot or hose on the shaft to seal the inside....
kz650 1978 Q/A 29 Apr 2021 14:44 #847705
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
If you decide on the 78 tensioner get a new nos spring on ebay for it............ BIG diff in tension.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
kz650 1978 Q/A 29 Apr 2021 15:01 #847706
  • katit
Ebay got springs for both newer and older. :)
Any collective wisdom on which tensioner better? If they made a change - must be better if newer?
kz650 1978 Q/A 29 Apr 2021 15:35 #847709
  • gordone
  • gordone's Avatar
  • Thank you received: 67
I have seen people have drilled whole in end off the tensioner and made some threads and used a long bolt to adjust with.
mod it to semi manual?
Project:
Last edit: by gordone.
