  • Page:
  • 1
Can I reuse head gasket? 21 Nov 2020 22:40 #838731
  • Ojisan rider
  • Ojisan rider's Avatar Topic Author
  • Thank you received: 63
Aloha guys. And before you jump the gun and say never! here is my situation.
I have my engine sitting in my living room for now. rebuild it and it's almost complete. It's sealed and ready to install new clutch, both steel and friction. When this happen, engine will sit in the frame. BUT!! As I was going through my new parts collection, I found that I forgot to install the front cam chain guide (new)!! No, I didn't rush. For some reason, it completely slipped out of my mind. Hate getting old..........................
Anyway, above is the reason for my question. I need to take the head off to install it. Head has been torqued but never ran. Can I re-use it? I will probably replace the o-ring, and I need to order some other small stuff, so buying the stuff is no problem. But if I can save few bucks, I'm leaning towards just that, thanks to COVID (Like everything else, need to balance the budget due to hour cut).
Any thought on this?
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
Can I reuse head gasket? 21 Nov 2020 23:44 #838732
  • kevski
  • kevski's Avatar
  • Thank you received: 154
Yes, as it has not been run nothing has settled into shape even the o rings will be fine if they are new.
Can I reuse head gasket? 22 Nov 2020 01:56 #838733
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 431
kevski wrote: Yes, as it has not been run nothing has settled into shape even the o rings will be fine if they are new.
I agree.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
Can I reuse head gasket? 22 Nov 2020 05:09 #838735
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
If they are undamaged I would probably take a chance and re-use them. Any damage at all and I would replace.
Can I reuse head gasket? 22 Nov 2020 06:09 #838737
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Thank you received: 1972
hardrockminer wrote: If they are undamaged I would probably take a chance and re-use them. Any damage at all and I would replace.
I Support
Can I reuse head gasket? 22 Nov 2020 07:59 #838740
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 133
I have done the same once or twice. Torqued down a head then had to remove it for some reason. Didn't cause a problem.
I tend to torque heads near the lower end torque range, than if this happens, to the upper torque value on the second go.
94 KE100
81 CM200t
82 KZ305
79 KZ400
85 VT 500c
85 VF1100c
Can I reuse head gasket? 22 Nov 2020 14:54 #838748
  • Ojisan rider
Thanks for all your advice guys.
You guys just save me $130+. I will reuse it and hope it will work out.
Thanks!
  • Page:
  • 1
