Dr. Phillis said, "brass stud". I am going to try some 1/8 or 3/16 brass rod and just braze it to the pipe and use the slide hammer. If it's that thin that I have to worry about burning a hole while welding, the brass should be plenty tough for pulling it out. I've been soldering for 40 years and am damn good at it. Electronics, plumbing, sheet metal. Just started brazing. It's the same thing, but strangely different. The art seems to be in pickng the right flux and filler and I'm still finger painting stick men when it comes to that. Other than that, it's heat management, just like soldering and as I'm learning, welding.
There's no down side with these generally crappy pipes.
I have been teaching myself welding and managed to join a couple of inches of 20 guage sheet, radially, to a 3/8 rod the other day. I really need a better gas torch. This harbor freight POS is a PITA to set a decent flame on. Once set it seems to hold pretty well. I'm still having trouble getting a decent start with the MIG. Once I get going I can make a decent bead but the first 1/2 inch or so looks like crap. Not good if all one wants is a 1/2 inch bead
![:-) :-)](/media/kunena/emoticons/smile.png)
Thanks to a very generous landlord for letting me use his welding stuff. Gonna save up and buy him a TIG adapter just so I can play with it.
Sorting out valve train first. Then find/fix problem that sent PO to valve train, ride a bit, then pipes.
-Duck
