  • Page:
  • 1
Torque Specs for Head 11 Apr 2006 15:35 #38716
  • Gune
  • Gune's Avatar Topic Author
  • Thank you received: 0
Hello Guys i just got my head back from the shop, and is ready to be installed.The only problem is I dont have the torque specs. I have a 1983 GPZ 305. It has the kz 305 motor. The dealer could not provide me with this information because they did not have the manual on hand, neither could they have ordered it. Is there anything else I could cross refrence with? Any thoughts.....
Torque Specs for Head 11 Apr 2006 18:28 #38778
  • wiredgeorge
  • wiredgeorge's Avatar
  • Thank you received: 44
Gune, I certainly can't help you but since your engine is similar to a KZ400/KZ400, I would suspect one of those folks could provide some useful info. If I owned one of the small twins and it used 8mm studs, I would probably FIRST use copper crush washers (if they were originally installed) after annealing them. This process involves heating with a torch till red hot and dropping into water to restore the elasticity (crushability?). Then, I would torque the nuts in a crossing pattern working from in to out and first torque to 18 ft/lbs then retorquing in the same crossing pattern from in to out at 25 ft/lbs. A better answer MIGHT be had on Odd Ivars KZ400 web site which is surely linked somewhere here on this site. I am pretty sure the 400 engine will have very similar toruing pattern and specs.
Torque Specs for Head 12 Apr 2006 11:11 #38965
  • rodneyo
  • rodneyo's Avatar
  • Thank you received: 1
You can order a clymer manual from amazon.com pretty cheap.I think those guys were just lazy.
Torque Specs for Head 12 Apr 2006 11:25 #38968
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 304
Gune, if no one answers your query by tonight, I think I have the KHI shop manual for the Z305 at home. I'll either post the specs or scan and post the specs on this site (scanning will take a day longer as my scanner is at work).
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Torque Specs for Head 13 Apr 2006 06:32 #39165
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Gune...I have scanned the requested info but the site is not accepting any uploads at the moment...I'll try again later.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Page:
  • 1
