  • Page:
  • 1
Cam chain tensioner z550 b2 06 Apr 2006 06:10 #37189
  • ivopeters
  • ivopeters's Avatar Topic Author
  • Thank you received: 0
Hi, I'm new on this forum and I have a question about a cam chain tensioner of a z550 b2.
My tensioner has broken and I'm trying to find a new one, but I can't find it anywhere.
Does anybody know if there are other models which are using the same tensioner so I can replace mine?
Thanks,
Ivo
Post edited by: ivopeters, at: 2006/04/06 09:10
Cam chain tensioner z550 b2 06 Apr 2006 06:22 #37194
  • 81kz550b2
  • 81kz550b2's Avatar
Hey Ivo,
It seems like a lot of these tensioners break. My thought is that this is at least partly Kawasaki's fault. The tensioner cap is 17mm nut, but if you don't look in the table to see how tight this nut should be tightened you normally just break the tensioner.
If you get your hands on a good one always be very careful when tightening this nut!
I never really tried, but it seems to me that the Suzuki cam chain tensioners of the early 80's look very very similar. Perhaps a Suzuki tensioner works on kz550? Or perhaps you can modify a Suzuki tensioner to make it work? Maybe someone here knows something about it.
1981 kz550b2
1984 kz750E (Turbo)
1989 GPz1000RX (Burnt down on the German Autobahn...)
Enschede
Netherlands
Cam chain tensioner z550 b2 06 Apr 2006 15:54 #37312
  • tellietubbie
  • tellietubbie's Avatar
  • Visitor
Hi Ivo, if your b2 is up to 1985 you should find any 550 from early eighties will do. To be found on Ebay:woohoo:
Cam chain tensioner z550 b2 06 Apr 2006 22:48 #37460
  • gas
  • gas's Avatar
Thanks,
Ivo<br><br>Post edited by: ivopeters, at: 2006/04/06 09:10
I cross referenced an 81 KZ 550 A2. It gave me an 85 bike count, meaning that 85 other Kawasaki models use a cam chain tensioner compatible with yours. The software didn't list any B models, but that was likely just a glitch or some missed info. The models include 550 to 84, ZL 600, ZX 600 (NINJA) from 85-96, KZ 1000 81-97, some ZN and ZX 1100'S.
Cam chain tensioner z550 b2 06 Apr 2006 22:59 #37466
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
  • Thank you received: 2
oopsie, i accidently gave one away with a load of parts two days ago, im sorry bud. my bad.
I was going to keep it too. i hate it when that happens.
Cam chain tensioner z550 b2 07 Apr 2006 09:49 #37574
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 237
According to the Kawasaki parts fiche, the same tensioner was used on a lot of bikes including ZX600, ZX1100, KZ1000 police models for about 20 years running. Should be very readilly available.
  • Page:
  • 1
