  • Page:
  • 1
Throttle Cables For 650/810 05 Apr 2006 18:58 #37058
  • reborn650
  • reborn650's Avatar Topic Author
  • Thank you received: 5
Hey gang. I am well under way with my engine upgrade...okay...I'm re-restoring the bike again. I am either a glutton for punishment or just plain addicted to playing with my old 650. I think the latter.
My question is this. Any opinions on which throttle cable will be required? I have ordered Mikuni 28 carbs from WG and they will be mated to the stock 650 head. My hope is that I can use the stock 650 throttle cables that I put on last summer.
Any advice would be appreciated.
1977 Kz 650 Custom - (Miss July in the 2006 Kzrider calendar.) Wiseco 810 kit, Kz750 cams, Kz750 intake valves, 750 GPz springs, Ported head, WG Mikuni 28's, Dyna Ignition and coils, MAC pipe, 13 tooth sprocket. Going back to original '77 Moon Dust Silver. Goal is to have a stock-looking bike that will tighten up any loose dental fillings off the light.
-1998 Jeep TJ Wrangler 4.0...
Throttle Cables For 650/810 05 Apr 2006 19:12 #37062
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
I going to think you'll be one of the first to try some of the mods and will be of help to many in the future.;)
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Throttle Cables For 650/810 05 Apr 2006 20:35 #37107
  • steell
  • steell's Avatar
  • Thank you received: 207
I think you should ask Wiredgeorge, I think he installs the carbs on his own bike and runs them prior to shipment, so I bet he can tell you from memory what, if anything, you need to do with the cables :)
Throttle Cables For 650/810 05 Apr 2006 21:42 #37131
  • reborn650
Thanks Rob and Steve-The bike is shaping up to be a compilation of input from many many members who have answered my tech questions with previous postings and current threads. Maybe when I am done I will write a little overview of what I did right (and wrong) so others will have an idea on what to do if they want to do a similar upgrade to their middleweight K bikes.
I just want something that is bulletproof and will keep my crotch rocket riding buddies wondering how this old bike can keep them in my sights. I still haven't told any of them what I am doing....I'll save that for the first time I light it up with them at a light:)
I'll fire off an email to George and get his input on the cables and carb boot suggestion while I am at it.
Cheers-Colin Firth -Ontario Canada
Throttle Cables For 650/810 05 Apr 2006 23:05 #37146
  • 77KZ650
  • 77KZ650's Avatar
  • Thank you received: 7
Should be the same, they all use the push pull throttle right?
Scott
07 MDP Rookie of the Year
Throttle Cables For 650/810 06 Apr 2006 06:29 #37195
  • steell
  • steell's Avatar
Scott
There are different push/pull cables for different carbs. I know that the 79 KZ650SR cable won't fit on the 83 GPz750 carbs because the part on the carbs that the cable attaches to is different, my nephew took the cables and throttle assembly off my GPz750 to use on his GPz750 powered KZ650SR because of that. I don't know what others are different.
Throttle Cables For 650/810 06 Apr 2006 15:54 #37311
  • Dave Sloan
  • Dave Sloan's Avatar
Hi Guys,
I've have been using a Z1300 throttle assembly and cables on my z650 for years, with stock 24mm carbs then 26mm carbs and now (using only 1 cable) on the fuel injection. I changed to the 1300 one after I had bashed the steel bends on the 650 unit into the tank when I had a set of drag bars on the bike the cables come out of the top off the assembly and not the bottom.
Cheers
Z650B2 - Injected
  • Page:
  • 1
