  • Page:
  • 1
tach 26 Mar 2006 08:58 #34412
  • leitrum
  • leitrum's Avatar Topic Author
  • Thank you received: 0
tach doesn't work,how can i test if its the cable or tach so i don't have to buy both.
tach 26 Mar 2006 09:06 #34415
  • btchalice
  • btchalice's Avatar
  • Thank you received: 7
unhook the cable from the tach and start the motor if it spins its the tach unless its electric
Post edited by: btchalice, at: 2006/03/26 12:07
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
tach 26 Mar 2006 09:45 #34423
  • leitrum
no not electrical will ck that thx.
tach 27 Mar 2006 20:11 #34816
  • xstreamcanadian
  • xstreamcanadian's Avatar
  • Thank you received: 6
you can also run your tach with a drill.....
tach 28 Mar 2006 06:43 #34903
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Remove the engine end of the cable and attach it to a drill, then spin away. Careful of the direction of the drill, forward or reverse, don't know firsthand which way it's supposed to go. Look at the cable while doing the cable test:"unhook the cable from the tach and start the motor if it spins ", to check for direction. You can use a spare cable if you don't want to disconnect the engine end.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
tach 28 Mar 2006 11:44 #34966
  • kevco
  • kevco's Avatar
It spins in reverse.
  • Page:
  • 1
