VIDEO 9 Country KZ/Z Camping Adventure VIDEO
- Ian T-J
20 Feb 2021 00:34
Grab a beer
and take a look at this KZ/Z adventure
The following user(s) said Thank You: mopguy, Grcko, howardhb
- howardhb
- God, I trust
Re: VIDEO 9 Country KZ/Z Camping Adventure VIDEO
20 Feb 2021 05:22
Simply marvelous!
'81 GPz 550 D1
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/11-projects/617040-1981-...-rstomod-elr-tribute
'82 Yamaha YB100 Fizzie
The following user(s) said Thank You: Ian T-J
- ayeckley
20 Feb 2021 05:29
Very nice. Did you wind up reworking the petcock?
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
- Ian T-J
20 Feb 2021 06:20The short answer is "No"ayeckley wrote: Very nice. Did you wind up reworking the petcock?
I kept getting asked this question on the YouTube video so I've written a detailed reply within the listing text.
"I've had so many questions asking if I fixed the high speed power loss issue.
During the trip provided I kept my speed below 65mph the bike was fine, so I tried to use smaller road and therefore slower speeds.
I was also scared if I tried to fix the issue I would waste half a day on the roadside, and perhaps make the issue worse.
Basically I could live with a slow top speed, its my riding style.
I still haven’t fixed the high speed power loss issue,
2020 and the Covid pandemic restrictions meant the Old Zed had very little use, simply short local low speed Sunday afternoon trips.
When Covid restrictions are lifted I’ll fix the issue"
20 Feb 2021 06:47 - 20 Feb 2021 06:51
Cool trip. Did you perform a valve clearance check before leaving?
Last edit: 20 Feb 2021 06:51 by TexasKZ.
- mopguy
20 Feb 2021 08:03
Great video..
20 Feb 2021 08:31
I'm surprised no one suggested you connect the vacuum line to one of your test ports. A piece of vacuum line would be an easy fix and answer the question. Cool video.
- Ian T-J
20 Feb 2021 10:49Time to confess, this old Z650 runs on a cocktail of Love and NeglectTexasKZ wrote: Cool trip. Did you perform a valve clearance check before leaving?
I've owned this bike for over 30 years and always serviced it myself.
I can only once remember adjusting the valve clearances, buckets and shims.
Although the top end isn't too noisy !
The engine is leaking oil like an old English motorcycle, one day I will have to take it out and give it a very big over hall.
- Ian T-J
20 Feb 2021 10:55Thanks StevenSWest wrote: I'm surprised no one suggested you connect the vacuum line to one of your test ports. A piece of vacuum line would be an easy fix and answer the question. Cool video.
Only 2 days ago on YouTube a Gerald Scott who uses this forum gave me the same advice
(Test Ports = Vacuum Gauge Ports)
He's the reason I've just restarted visiting this forum
20 Feb 2021 10:58 - 20 Feb 2021 10:58Ian T-J wrote: .......................
Leaking oil? From where? I bought my 1977 KZ650 new in 1977 and with more than 62,000 miles it doe not leak a single drop of oil. Is the oil leak where the tachometer cable attaches to the engine? If so, that's very easy to fix. BTW, I owned a BSA for many years, so I know how an old English motorcycle can leak. :laugh: :laugh: :laugh: :laugh: Ed
Last edit: 20 Feb 2021 10:58 by 650ed.
- Ian T-J
20 Feb 2021 11:17Hi Ed650ed wrote:Ian T-J wrote: .......................
Leaking oil? From where? I bought my 1977 KZ650 new in 1977 and with more than 62,000 miles it doe not leak a single drop of oil. Is the oil leak where the tachometer cable attaches to the engine? Ed
It's mainly leaking from the gasket between the barrels and head.
It's leaked for years and years.
I wear black jeans and boots and simply top up the oil !
I do recall replacing this gasket at one point and have torqued down the head several times subsequently.
20 Feb 2021 11:24 - 20 Feb 2021 11:25Ian T-J wrote:Thanks StevenSWest wrote: I'm surprised no one suggested you connect the vacuum line to one of your test ports. A piece of vacuum line would be an easy fix and answer the question. Cool video.
It's Steve. I changed it when I turned 18. They only used it when they were mad or wanted something from me. I got my family to stop calling me Steven but some still did when they wanted my attention. My reply was YEAH WHAT DO YOU WANT? That would shut them down. :lol:
If you open the petcock (I'm not suggesting it) you'll find a small hole where the fuel bypasses the valve to fill the bowls. When vacuum is applied the valve opens allowing full flow of fuel. Never liked them. If it were me I'd use two ports with a tee so the petcock gets a constant vacuum signal. Having just one seems to me would overwork the diaphragm at idle. I know they only use one port usually on the #3 carb just in front of the slide and my 33's have it not my 28's.
Give it a shot and let us now how it worked out for you.
Last edit: 20 Feb 2021 11:25 by SWest. Reason: sp
