Z1R 2.0 What The?
- z1kzonly
Z1R 2.0 What The?
20 Nov 2023 06:54
Double engine Z1R, even has a center stand.
This is on Mecums website for auction in Las Vegas Jan. 2024. They call it a 73 Z1?
I'm surprised I've never seen this before. Has anyone? Cool as F!
mecum does not let you copy their photos?
www.mecum.com/lots/1106697/1973-kawasaki-z1-twin-engine-custom/
Re: Z1R 2.0 What The?
20 Nov 2023 07:14"Where there's a will"Double engine Z1R, even has a center stand. This is on Mecums website for auction in Las Vegas Jan. 2024. They call it a 73 Z1?
The following user(s) said Thank You: BCScott
20 Nov 2023 16:18
Sent pictures to Wheelhop and Street Fighter Dave. I’m impressed with the mechanics of marrying the two. Dave noticed the long reach from set to bars. Not doing any serious turns on it that’s for sure
20 Nov 2023 18:07
The following user(s) said Thank You: !Seymore, Wookie58
- sf4t7
20 Nov 2023 20:00 - 20 Nov 2023 20:05
I'm curious how the drives / chains are combined. Can't really tell from the photo.
maybe the long reach to the bars is not an issue when you crank the throttle - it probably stretches your arms under acceleration.
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 20 Nov 2023 20:05 by sf4t7.
20 Nov 2023 23:07It looks to me like there is no "trans" on the front motor and the two cranks are joined behind the custom cover on the generator side?
- rangeroy
21 Nov 2023 01:34
FFS, if youre going to do it, do it right
Millyard Kawasaki Z1 1600 V8 motorcycle - How its made - YouTube
1977 z650
21 Nov 2023 04:22
If you're running a MAC you can take a screen shot (Shift, Command 5) and adjust it to the dimensions you want on the screen.
- sf4t7
21 Nov 2023 05:30
Guy - upon looking closer, I will agree with no trans on the front motor.
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- zed1015
21 Nov 2023 09:58
Cutting off the trans and boxing in the remaining crankcase was the usual mod on multi engined drag bikes such as Henk Vinks Big Spender etc.
The bike in the pic is either a sanitised ex dragbike or at least using the modified front cases and tandem drive from one.
- willemZ900
- Z1B 4 ever
21 Nov 2023 13:06 - 21 Nov 2023 13:07
Two sets Mikuni VM29 smoothys, not big for such a bike
Last edit: 21 Nov 2023 13:07 by willemZ900.
- Injected
21 Nov 2023 13:20 - 21 Nov 2023 13:23
I saw pictures of that same bike about 10 years back. Funny thing about it is you can make the same power with a single worked on KZ engine.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 21 Nov 2023 13:23 by Injected. Reason: info
