Carbs coughing at low speed
  • malcolm9kevin@aol.com
  • malcolm9kevin@aol.com's Avatar Topic Author
29 Aug 2023 11:43 - 29 Aug 2023 13:25
#888828
Hi can anyone help with a problem I have with my 1976 z1 900. Got the usual stuff done to it Wiseco 1015 cams big valves mikuni 29mm smoothbores what’s happening is it starts first go it ticks over fine the plugs are a good colour it’s when riding if you’re moving at a steady speed 40 50 60 it runs a bit rough and you get spiting from the carbs but as soon as you open it up it flys should I be looking at the Carbs all the timing
Last edit: 29 Aug 2023 13:25 by Street Fighter LTD.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Re: Carbs coughing at low speed
29 Aug 2023 15:47
#888841
Stunning Harris (Magnum II ?) I may come calling for a BOTM feature
The following user(s) said Thank You: malcolm9kevin@aol.com
  • zed1015
  • zed1015's Avatar
29 Aug 2023 16:03
#888842
Could be several causes but the usual suspects are a lean condition , valve clearances or  ignition timing.
The speed range it affects means very little though.
You need to identify the throttle position it occurs at to isolate the fuel circuit that is causing the issue if it is the carbs.
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
30 Aug 2023 01:14
#888850
I am running vm29 too, what are the mains, pilots and how many turns of the airscrews?
30 Aug 2023 06:38
#888856
Hi 120 mains
17.5 pilot
0.9 air jet
air screws are only just open about 1/4 to 1/2 turns out I’m using foam filters
do you think I need bigger pilot jets or smaller air jets
30 Aug 2023 06:42
#888857
Hi it’s a magnum 1
it’s the 10th one made iv had since 1979
30 Aug 2023 08:58
#888862
Hi thanks for your reply
bike is only done 250 miles since rebuild so the valve clearances should be okay The problem is only When throttle is partly open so I’m guessing it’s the pilot circuit the air screws are only turned out between 1/4 and 3/4.carbs 2and 3 are open the most as the tank smothers them a bit . As for the timing am using dyna s and dyna coils with the timing on full advance thanks
ps I’ve only just got back on the road after 23 years
30 Aug 2023 09:35 - 30 Aug 2023 12:30
#888865
This is me just after I got it
Last edit: 30 Aug 2023 12:30 by Street Fighter LTD.
  • zed1015
  • zed1015's Avatar
30 Aug 2023 12:35
#888869
Hi 120 mains
17.5 pilot
0.9 air jet
Try a 0.6 main air jet..
30 Aug 2023 14:02 - 30 Aug 2023 14:04
#888870
That was my next try but could only get 0.5 so I’ve got a set of drills also can you get choke plungers ?
Last edit: 30 Aug 2023 14:04 by malcolm9kevin@aol.com.
  • zed1015
  • zed1015's Avatar
30 Aug 2023 15:34
#888874
Yes! I can repair your original plungers.
Either through my ebay listing or £10 cheaper direct via contact at - zed.1015@yahoo.co.uk
Mikuni Choke plunger VITON seal repair. KAWASAKI Z1,Z650,z900,Z1000,Z1R,Z1300 | eBay
  • Wookie58
  • Wookie58's Avatar
  • Moderator
31 Aug 2023 10:48
#888888
Hi it’s a magnum 1
I love them, I had a Honda powered Magnum II a while back (20 years ago)
