Z2 750 crank (Bossie the Kaw) 11 Sep 2019 16:29 #810721
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2629
Just going to do a light cleanup on the ports.
Z2 750 crank (Bossie the Kaw) 16 Sep 2019 07:15 #810921
  • SWest
  • 10 22 2014
Cleaning up the head for welding.
Z2 750 crank (Bossie the Kaw) 16 Sep 2019 14:20 #810935
  • SWest
  • 10 22 2014
One step closer.
Z2 750 crank (Bossie the Kaw) 17 Sep 2019 06:40 #810961
  • SWest
  • 10 22 2014
Two steps back. looks like I need exhaust valves. :unsure:
Z2 750 crank (Bossie the Kaw) 17 Sep 2019 20:45 #810993
  • SWest
  • 10 22 2014
The valves are junk. :dry:
Last edit: by SWest. Reason: Edited video
Z2 750 crank (Bossie the Kaw) 28 Sep 2019 12:44 #811483
  • SWest
  • 10 22 2014
Won't be long until I tear her down again. Until then she's running good.
Z2 750 crank (Bossie the Kaw) 30 Sep 2019 08:21 #811526
  • SWest
  • 10 22 2014
Dug out some old Splitfire plugs I had in a box. Good plugs.
Z2 750 crank (Bossie the Kaw) 06 Oct 2019 07:30 #811915
  • SWest
  • 10 22 2014
I think I found a few gremlins.
Z2 750 crank (Bossie the Kaw) 06 Oct 2019 08:52 #811920
  • SWest
  • 10 22 2014
No eBay APP ID and/or Cert ID defined in Kunena configurationI ordered this to replace my HID. Should have it Monday.
Z2 750 crank (Bossie the Kaw) 06 Oct 2019 13:20 #811934
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1865
Hi Steve, I just completed an Halogen headlight conversion, during the front end, gauge and fork rebuild, but not real happy with the output of the 60/55 H4 bulb. To me it doesn't seem much brighter than the original Stanley sealed beam. How does this bulb compare? Looks like it would fit in the Halogen conversion carrier? Would any other changes need to be made to the charging system to use this bulb?
Z2 750 crank (Bossie the Kaw) 06 Oct 2019 15:12 #811939
  • SWest
  • 10 22 2014
It is supposed to be plug and play. Should get it tomorrow. I'll post a clip about it. Hopefully it'll last but I'm sceptical about it.
Z2 750 crank (Bossie the Kaw) 08 Oct 2019 20:38 #812101
  • SWest
  • 10 22 2014
Nice to have a new cable. I forgot how easy it was on the clutch hand. I started a thread on the LED headlight.
