Z2 750 crank (Bossie the Kaw) 13 Dec 2018 07:16 #795070
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2649
Put the 3rd and 4th coats on. Next will be wet sanding when I get the clear coat but for now I'll just look and admire it. :)
Z2 750 crank (Bossie the Kaw) 13 Dec 2018 18:48 #795113
  • SWest
  • 10 22 2014
Missed a spot. :(
Last edit: by SWest.
Z2 750 crank (Bossie the Kaw) 14 Dec 2018 18:23 #795143
  • Jimbo302
  • Jimbo302's Avatar
  • Thank you received: 7
Nice looking bike. Did I miss what happened with the crank discussion, replaced it?
Z2 750 crank (Bossie the Kaw) 14 Dec 2018 18:45 #795144
  • SWest
  • 10 22 2014
I wound up buying a 903 crank and have the 750 crank for sale. Got more compression and ponies. The 750 crank weighs the same but the shorter stroke lowered the compression. :blush:
Z2 750 crank (Bossie the Kaw) 14 Dec 2018 21:08 #795146
  • Barry1
  • Barry1's Avatar
  • Thank you received: 1
Steve, What brand of clear coat do you use?
Z2 750 crank (Bossie the Kaw) 15 Dec 2018 08:40 #795171
  • SWest
  • 10 22 2014
I've tried all of the off the shelf auto paints even the clear engine paints and was disappointed with the results. This time I'm going to use the Spray Max 2K. Some of our members recommend it and have posted beautiful work with it. This will be a test case for me. :unsure:
The following user(s) said Thank You: Barry1
Z2 750 crank (Bossie the Kaw) 15 Dec 2018 09:47 #795181
  • SWest
  • 10 22 2014
From what I've read I may have waited too long to clear coat the tank. I might have to run into town and get another can of base coat. That being the case I can fix the small blemishes before I do it. :unsure:
Z2 750 crank (Bossie the Kaw) 16 Dec 2018 07:30 #795217
  • SWest
  • 10 22 2014
Took the extra steps so I should be able to finish today. Hope it was worth it. :whistle:
Z2 750 crank (Bossie the Kaw) 16 Dec 2018 21:28 #795267
  • SWest
  • 10 22 2014
Got it done. Good enough for now. :dry:
Z2 750 crank (Bossie the Kaw) 17 Dec 2018 15:38 #795325
  • SWest
  • 10 22 2014
Now for the side covers.
Z2 750 crank (Bossie the Kaw) 17 Dec 2018 20:30 #795343
  • SWest
  • 10 22 2014
Got them on the bike. B)
Z2 750 crank (Bossie the Kaw) 18 Dec 2018 14:08 #795374
  • SWest
  • 10 22 2014
Got to fix the seat before I can put the new tank on the bike.
