Z2 750 crank (Bossie the Kaw) 06 Dec 2016 05:18 #749631
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2638
No, 58 as opposed to 66.
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 06:49 #749641
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
Wow I thought I read one time it was only a 3mm difference...... 8mm that's like 5/16ths of an inch isn't it?.... Have no idea but man you might a been running 6 or 7 to 1 with that don't you think ??
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 07:07 #749644
  • SWest
  • 10 22 2014
Yeah, with the Wiseco's I didn't notice it. When I lunched another piston and had to use the stock 1000 pistons that came with the 1015 barrels, it was obvious. It still ran great, a little better when I put the 10.25/1's back in. I still haven't done a compression test. I will before I tear it down again. Says a lot about these motors. B)
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 16:19 #749679
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
swest wrote: No, 58 as opposed to 66.
Wow.... I never realized that you were down 165cc at 6:1 - 7:1 compression ... You're going to have to learn how to ride all over again!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 17:12 #749680
  • SWest
  • 10 22 2014
Might be a blessing in disguise. How did you come up with those figures?
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 18:16 #749687
  • missionkz
swest wrote: Might be a blessing in disguise. How did you come up with those figures?
wild ass guess and shorter stroke with same bore as a 1015 engine?
Bruce
1977 KZ1000A1
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 18:20 #749688
  • SWest
  • 10 22 2014
I'm going to fix my compression tester. It'll give us a better idea what it is. :whistle:
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 18:26 #749690
  • missionkz
I wish I would have written it down but I think mine was around 175psi a couple weeks after I put the 1075 kit in.
That was about 5000 miles ago.
Bruce
1977 KZ1000A1
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 18:54 #749692
  • missionkz
OK daydreaming.
58mm stroke with 70mm bore?
So 35sqrd x3.1416 x 58
892cc?
But you are running those 70mm 10:1 pistons so ... even with the stroke not pushing the piston further up into the combustion chamber, your actual compression is probably more then 8:1.
Bruce
1977 KZ1000A1
Last edit: by missionkz.
Z2 750 crank (Bossie the Kaw) 06 Dec 2016 19:01 #749694
  • SWest
  • 10 22 2014
I want to weigh both cranks to see if there is a difference or if it's just shorter rods. Looks like something that hasn't been done before. :)
Z2 750 crank (Bossie the Kaw) 10 Dec 2016 02:23 #749876
  • cjcrug
  • cjcrug's Avatar
Nice pass man, looks like it pulls purty good
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Dyna green coils
K and n pods
Andrews 2x cams
Z2 750 crank (Bossie the Kaw) 10 Dec 2016 02:26 #749877
  • cjcrug
  • cjcrug's Avatar
Lol idk how my post got two pages forward, it was a reply to the video
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Dyna green coils
K and n pods
Andrews 2x cams
