Z2 750 crank (Bossie the Kaw) 20 Jan 2022 13:10 #860793
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2621
Maybe it happened for a reason.
Z2 750 crank (Bossie the Kaw) 20 Jan 2022 16:14 #860799
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
Hey Steve, I'm still using the cut strips of 1/16" thick HDPE sheet material behind the hose clamps to hold the rings in.  The slick material surface protects the pistons as the sleeves slide past.  Besides that, the sleeves engage with the entire 1/16" strip edge, and glide over the rings when the clamps are snugged just right.
1982 KZ1100-A2
Last edit: by daveo.
Z2 750 crank (Bossie the Kaw) 21 Jan 2022 07:06 #860822
  • SWest
  • 10 22 2014
The rings will be here today. That was quick.
blog.wiseco.com/everything-you-need-to-know-about-ring-gap
Last edit: by SWest. Reason: add link
Z2 750 crank (Bossie the Kaw) 22 Jan 2022 08:24 #860865
  • SWest
  • 10 22 2014
IT'S A GO
Z2 750 crank (Bossie the Kaw) 23 Jan 2022 11:36 #860933
  • SWest
  • 10 22 2014
One hurdle down.
Z2 750 crank (Bossie the Kaw) 23 Jan 2022 18:10 #860961
  • SWest
  • 10 22 2014
THE END IS NEAR.
Z2 750 crank (Bossie the Kaw) 24 Jan 2022 21:44 #861043
  • SWest
  • 10 22 2014
Getting closer.
Z2 750 crank (Bossie the Kaw) 25 Jan 2022 03:05 #861049
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
  • Thank you received: 52
Morning Steve, because you have more compression,  how much torque did you use on your cilinderhead? Good luck with your rebuild! Greetings of the cold foggy Netherlands. Willem
Z2 750 crank (Bossie the Kaw) 25 Jan 2022 06:51 #861057
  • SWest
  • 10 22 2014
I took it up to 25 foot pounds and will go to 30 before startup.
Z2 750 crank (Bossie the Kaw) 25 Jan 2022 12:44 #861069
  • willemZ900
  • Z1B 4 ever
Original studs or APE studs?
Z2 750 crank (Bossie the Kaw) 25 Jan 2022 13:51 #861080
  • SWest
  • 10 22 2014
APE
Z2 750 crank (Bossie the Kaw) 26 Jan 2022 12:34 #861138
  • SWest
  • 10 22 2014
Catching up on vids.
