  • Page:
  • 1
Liquid Stainless Steel?? 30 May 2007 14:32 #144967
  • Patton's Avatar Topic Author
  • Thank you received: 2098
Is this B.S. or what?
Liquid S/S :huh:
Liquid Stainless Steel?? 30 May 2007 14:37 #144968
  • Sputnic81
  • Sputnic81's Avatar
  • Thank you received: 0
Not really BS just a little out of the ordinary. Of course it is not ACTUALLY stainless steel just a silver colored paint. Some manufacturers sell appliances painted with a similar material. It looks as good as stainless, but is still magnetic (for the kiddos grade cards and paintings) and does not show the fingerprints as much (from the kiddos showing off said grade cards and paintings). If my stuff weren't old and in need of replacement I would consider something like this, seems a bit pricey though.
Liquid Stainless Steel?? 30 May 2007 14:57 #144972
  • fastestz1
  • fastestz1's Avatar
  • Thank you received: 3
would it work on exhaust systems?
Liquid Stainless Steel?? 30 May 2007 15:20 #144975
  • The Milkman
  • The Milkman's Avatar
  • Thank you received: 194
Ad says good to 300 degrees, not good enough for exhaust, I'm thinking about the frame though,;) ;)
Ride Safe
Liquid Stainless Steel?? 30 May 2007 16:39 #144990
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
  • Thank you received: 35
The rustoleum hammertone and aluminum finish both look real good if you are careful and coat with clear afterwards and cost a fraction...
Liquid Stainless Steel?? 30 May 2007 20:39 #145073
  • steell
  • steell's Avatar
  • Thank you received: 207
Some stainless steel is magnetic, and some isn't. I'll probably get this backwards, but IIRC, 300 series SS is magnetic and 400 series is non magnetic.
Liquid Stainless Steel?? 31 May 2007 07:10 #145190
  • wiredgeorge
  • wiredgeorge's Avatar
  • Thank you received: 44
I don't care what they call the stuff, I can't see the missus turning me loose on her appliances with a paint brush and can of paint hehe
  • Page:
  • 1
