  • Page:
  • 1
  • 2
Another A2 25 Nov 2023 06:06 #892035
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 251
Yeah, mine is the same as your 76 900 and your 650 so I'll keep it the same way.
Thanks
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Another A2 25 Nov 2023 06:36 #892036
  • ronnieV
  • ronnieV's Avatar Topic Author
  • Thank you received: 293
Is it usa built are opposite as Japan made?
Another A2 25 Nov 2023 09:26 #892041
  • sf4t7
  • sf4t7's Avatar
That would make more sense than totally random, but I don't know.  Someone with a US built KZ - help us out?
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Another A2 25 Nov 2023 09:47 #892042
  • ronnieV
Maybe not,I just checked my other 78a which is made in usa and it's the same as my Japan made 78a. I'm going to check my other frame stickers
Another A2 25 Nov 2023 13:25 #892052
  • sf4t7
  • sf4t7's Avatar
From my 74 Z1A
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Another A2 25 Nov 2023 14:43 #892055
  • urankjj
  • urankjj's Avatar
  • Thank you received: 201
If it helps, from my 77-KZ A1.
Another A2 25 Nov 2023 14:49 #892056
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1863
From a very reliable source, just this afternoon. I was told all Z1’s were like yours sf4t7. Then when they started to build the American Kz the orientation was mostly still like the Z1’s, but depending on time of day they could have been installed after a liquid lunch or late Friday afternoon and could have been placed either way and still passed inspection. Later on the Kz1000’s there is no predictable orientation. I was told if your replacing one put the new one on the way the old is/was. If you’re placing one on a head tube without one existing then as mentioned, up thru the kz900’s they are read from the left looking at the front of the bike. For the Kz1000’s its dealers choice with one caveat place them straight!
Another A2 25 Nov 2023 14:51 #892057
  • Mikaw
  • Mikaw's Avatar
Nice early bike.
  • Page:
  • 1
  • 2
