new to me 1978 KZ 1000
  • Treetall
  • Treetall's Avatar Topic Author
Re: new to me 1978 KZ 1000
11 May 2023 11:21
#884520
He seems to be stuck between a rock and a hard place! LOL Couldn't resist.
Where is this guy? I'll have to check him out!
I've been through Chase a number of times. I got a speeding ticket going through there on Hwy 1. I think it was a 70 km zone. That was back in the 80's.
  • Treetall
11 May 2023 11:45
#884522
I'm looking to get some brake lines from Earl's. The Speed Seal type that Nessism mentioned.
I didn't see it in Nessism's little tutorial, what size hose do we  run on the KZ's?
I was going to order some premade hoses from Z1. But they're out of some of the banjo's that I need.
Thanks
  • Treetall
11 May 2023 18:43
#884541
Another question!
The part # for the Carb Holders is 16065-028 for R/H and 029 L/H according to Partzilla and and couple others.
Z1 Enterprises has a set in stock but they're saying for 28mm. The 78 KZ1000 has a 26mm carbs correct?
There's a couple of other places that are stocking them as well, but don't say size. And Z1 has the best price.
  • Nessism
  • Nessism's Avatar
11 May 2023 19:04 - 11 May 2023 19:05
#884542
Thanks
-3 Speed Seal, w/10mm / 3/8" hose ends
The non-adjustable hose ends work fine, but the adjustable are a little more fault-tolerant.
This may help... www.thegsresources.com/_forum/forum/tech...-s-brake-line-thread
Last edit: 11 May 2023 19:05 by Nessism.
The following user(s) said Thank You: sf4t7, Treetall
  • sf4t7
  • sf4t7's Avatar
11 May 2023 21:45
#884544
Thanks Nessism, your brake line thread tutorial is clear and easy to follow.  Once again you've helped us learn something new.
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
12 May 2023 10:11
#884549
Apex is a great place to get your brake lines from. Raymond will set you up with a nice set of lines that will fit perfectly. We've got Apex lines on over half of our bikes. I put a set on the KZ 1000LTD recently.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
The following user(s) said Thank You: 78kawltd
  • Treetall
12 May 2023 19:20
#884571
Thanks Kelly
I'll look into them as well.
When I got this ole bike, I was concerned that some parts may be hard to find. So far it's been good. A few places are out of stock on a few things.
  • Kelly E
  • Kelly E's Avatar
12 May 2023 20:16 - 12 May 2023 20:21
#884573
The Apex lines also come with all new banjo bolts and they are in Canada. You can also get swivels if you need them for tight spots. I got one for the short line from the master cylinder to the junction block. You can see it under the headlight.
1983 Honda CB 1100F
And more
Last edit: 12 May 2023 20:21 by Kelly E.
  • sf4t7
  • sf4t7's Avatar
18 May 2023 15:27
#884875
Carb manifolds -- I remember seeing a post on this forum stated the outside diameter on the manifold end is the same for both the VM28 and VM26, only the throat of the carb is 26 or 28 mm.  therefore the same manifold would be used for both the VM26 and VM28, and the ones from Z1E will work.
Maybe another member can verify this ?
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Treetall
19 May 2023 20:44
#884955
Thanks Scotty
Maybe I'll pull one off and measure the manifold at the head and also on the carb, before I order any.
I'll try to get a good reading with a digital caliper. 2mm isn't much !! But .....!
  • zed1015
  • zed1015's Avatar
20 May 2023 03:15
#884957
Thanks Scotty
The carb manifods/boots are the same for the vm26 and 28.
The 2mm difference is in the inside bore not the outside of the spigot.
  • Treetall
21 Jun 2023 20:02
#886294
Has anyone in Canada ordered brake lines etc. from Earl's Performance Plumbing.
I was going to order some stuff. But it appears they only ship by UPS.
I've order different items over the years, shipping VIA UPS. But the border brokerage fees were almost criminal in my view.
I was hoping they ship USPS, it takes a bit longer, but no brokerage fees.
I may look into APEX brake lines, as a second option.
Thanks in advance
Tall
