new to me 1978 KZ 1000
- Treetall
Re: new to me 1978 KZ 1000
01 Feb 2024 10:40
Thanks for the advice guys!
I wired up a relay for the coils and I'm getting a nice spark now.
She only runs on 2 legs though.
Looks like the coil for cyl 2-3 is toast. I'm not getting any spark and no ohm reading on the secondary windings.
Any suggestions on where to a set of coils( with decent quality and price) ? Z1 Ent. and Z1 Parts have a sets running about $95. But I don't know the quality!
What ohm rating do I need to get? I'm running points at this point.
And maybe a stupid question. Should I replace both coils, Or just the toasted one?
Thanks again for the help!
Conrad
Conrad
01 Feb 2024 11:49
Check the FSM but I believe what you require are 3-4ohm primary and 10-15kohms secondary, given the bike is 45 years old with unknown history I would suggest replacing both (budget permitting) and keep the good one as a spare
- Treetall
01 Feb 2024 12:23Check the FSM but I believe what you require are 3-4ohm primary and 10-15kohms secondary, given the bike is 45 years old with unknown history I would suggest replacing both (budget permitting) and keep the good one as a spare
That’s what I was thinking. This one quit for no reason ( it worked last fall when I had it running)
I couldn’t find it in the FSM
but then again. My wife says I look with my eyes closed! Lol
Thats the readings I got from 1,4 coil
What brand of Coil do you normally buy?
01 Feb 2024 13:30
I think others can advise you best on brand, I know the theory and principles but have limited model specific experience
- sf4t7
01 Feb 2024 15:50
Don't wanna hijack this thread, but Rolf, plug wires and terminals are cheap enough new (especially if you make your own), why would you take a chance on some else's used ones?
Same with coils, you're better off with new.
Also, don't use resistor wires with resistor plugs, you can get away with one or the other but not both. Best is solid copper core wires with non resistor plugs. (my preference is Denso non resistor plugs, but there are others).
OK, now back to Treetall's subjects.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: Gdizard, Rolf1976_KZ900
- Rolf1976_KZ900
02 Feb 2024 03:45 - 02 Feb 2024 03:46Don't wanna hijack this thread, but Rolf, plug wires and terminals are cheap enough new (especially if you make your own), why would you take a chance on some else's used ones?
I have a new boyer bransden kit that came with new coils and wires and planning to install that ,but just want yellow or lime green plugwires for the looks.
I now have a dyna s installed ,but think it is a cheep replica. In August one coil melted when riding made bubbles underside of the coil and smelled burnt electrical. Some days before that i changed out the plugcaps to non resistor also used non resistor sparkplugs. The bike also had resistor placed on the plugwires itself. I changed to non resistor caps and plugs becuase the bike suddenly started to run bad and read that it is better to run with non resistance plugs and caps.
Then i found that the timingchain had jumped because of worn sliders rollers tensioner and chain .That has made me torn down the engine
I now have a little new problem that is when i will fire up the bike after rebuild of the engine im not sure what i will do with the ignition i mean if i will fire it up with the dyna s that sits on the bike and maybe melted the coil or if i shall install the boyer brasden kit before first start.After first start i will run the engine on road soon as possible to seat the rings not fiddling with adusting the ignition and engine idling.
Last edit: 02 Feb 2024 03:46 by Rolf1976_KZ900.
- Treetall
15 Feb 2024 19:57
So I ordered steering stem bearings from Fortnine. $60 C$ and free shipping. Just in case there are Canucks price comparing.
I also learned a new word! When the bearing makes the little indents in the race, its called Brinell or has gone Brinell!
I first attempted to cut some slots in the race, to make removal easier. but there's not enough shoulder for a punch.
I think it was Mikaw mentioned on here to weld a washer to the race. Worked a charm!
Here are some pics of my playing around!
The first is a chunk of ready rod to hold the washer while I welded it in place.
Second is laughable welding job, but it got the job done!
Third is my race install tool. Using the old bearings, I squeezed the new races into place. I know the thing looks like WTF! But it worked a peach. I've always had a problem with the races going cockeyed when I try to tap them in with a hammer.
The following user(s) said Thank You: sf4t7, howardhb, Wookie58
- sf4t7
15 Feb 2024 20:49
Thanks Treetall and Mikaw for that bearing race removal tip. I can't tell you how many punches I've had to grind square after rounding the tips trying to remove bearing races from front rotors or drums over the last 40 years. As they said in the old Guinness commercial - BRILLIANT !
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
16 Feb 2024 04:12
Brinell is actually a hardness scale.
en.wikipedia.org/wiki/Brinell_scale#:~:t...0materials%20science .
- Treetall
16 Feb 2024 19:52Brinell is actually a hardness scale.
I looked at it after I posted it, and ya I didn't have it right.
What I should maybe said was " It's lost it's Brinell" ! But that's not exactly right either!
There I go, trying to be a fart smeller! LOL
- sf4t7
16 Feb 2024 20:05 - 16 Feb 2024 20:06
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 16 Feb 2024 20:06 by sf4t7.
- Treetall
11 Nov 2024 11:17
Hey Guys
Hope everyone is doing well! I've been away for a bit, work, life etc.
So to bring things up to speed. I got the KZ running but not well. I cleaned the carbs and put in an O ring kit from Nessism. I can get er to idle but any throttle and she dies. Unless I feather the throttle a lot. Float heights are set properly as per manual. The bike didn't come with the air box, so I bought a good set of UNI air filters,( as recommended here). It's got a Mac Header.
It's got the stock Mikuni Carbs. It has a 110 Main jet and a 15 Pilot jet. So I'm thinking I need to up the Pilot jet a size or 2.
Any recommendations on what size I should start with?
Thanks
Thanks
