new to me 1978 KZ 1000
  • Treetall
  • Treetall's Avatar Topic Author
05 Apr 2023 11:55
#882543
Hello Everyone.
I acquired a 1978 KZ1000 back around the end of Jan. From a friend who's owned it since 1988. It's been park since 2011. He was going to restore it when he retired. But due to health issues that's not going to happen. I've been lurking here since.
The motor was seized. I got it to break loose. I cleaned the carbs, and cleaned and lined the gas tank.
I wanted to see if i could get it running before I got too carried away!  This I was able to accomplish !! She only runs for a minute or so and dies. So I know I need to redo the carbs, the o-rings are hard and brittle and also a number of other parts need replacing.
My Question is where can I source a set of o-rings to rebuild the carbs. Some of them seem to be reg. metric o-rings. But others are an odd size, ie: Pilot screw o-ring.
The rest of the carbs are in good shape. As mentioned here, I don't need new jets etc.
BTW There's a lot of really good info and write ups on this site.
Thanks
Conrad
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: new to me 1978 KZ 1000
05 Apr 2023 12:26
#882545
Welcome to KZRider
Ed  who's  screen name here is Nessium  will be a great source of information and probably parts for your rebuild
We also thrive on bike pictures and projects so give posting pictures a shot
  • Warren3200gt
  • Warren3200gt's Avatar
05 Apr 2023 12:29
#882546
Welcome, plenty of info and advice here from seasoned Z/KZ riders/spanner men.
Best source for sparts  will be dependent on which side of the Atlantic you reside.
Oh, and pics, we love pics.
  • Mikaw
  • Mikaw's Avatar
05 Apr 2023 12:54
#882548
Welcome. Sounds like your a capable person. Good for you to here in run. That’s a big accomplishment. You really need to post pictures so we can identify parts and get you correct information and goodies. After 40+ years assuming is not a good tactic.
  • Treetall
06 Apr 2023 10:24 - 06 Apr 2023 12:02
#882566
Thanks for the replies guys.
I tried to PM Ed ( Nessium)for O-Rings.  But I guess I haven't been here long enough or need to post a few first. So that was " NO TOUCHY"!
I live on this side of the 49th in this frozen tundra.
I've had my share of KZ's back in the 80's. I had a 1980 kz750, an 81 or 82 CSR 1000, and an 82 or 83 1100 LTD.
Here's a couple of pics. should be alright for size!
Last edit: 06 Apr 2023 12:02 by Street Fighter LTD.
  • Moderator
  • Moderator
06 Apr 2023 12:04
#882568
Nice project treetall
Next time click the insert all tab and your pictures will appear fullsize
 If Nessium doesnt see this soon we will get you through to him
  • Nessism
  • Nessism's Avatar
  • Away
06 Apr 2023 17:03
#882578
Please post your email address and I'll get in touch regarding O-rings.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
06 Apr 2023 23:19
#882587
Treetall I have sent Nessism your email so you don't need to post it on the forum
The following user(s) said Thank You: Treetall
  • Treetall
07 Apr 2023 11:00
#882612
So first on the list was to get er unseized. Not sure which cylinder was stuck. But there was no spark plug in hole # 2, and hole # 3 had a seized spark plug.
After several different attempts with penetrating oils and heat etc. We managed to snap off the seized plug!  PERFECT !!  But that's for later.
So after I got the plug out, I applied a number of different suggested penetrants and heat to break er loose. In the process I read  somewhere, to turn over the motor I should put a wrench on the 17mm nut on the ignition side of the motor. I was somewhat leery, so I put a short wrench on it for less torque. It doesn't take much to break this bolt. Don't ask me how I know!
I also tried breaking the engine loose using the back wheel on the center stand. In the end I dragged the bike back and forth over a rough patch of cement in my shop and Eureka it broke loose!
By the way, Drilling out the broken bolt on the ignition side was a bitch!
Attachment not found
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
07 Apr 2023 11:55
#882613
Do you have left handed drill bits? Most of the time (but not always) the remains of the bolt will unscrew before you go all the way through.
We recently had to drill out a dozen stuck case cover screws on the 78' KL 250. With the left handed bits every one them unscrewed just before the head popped off. A few months ago we had to drill a case cover screw all the way out on the 80' Suzuki GS 1100E. It was in a spot that couldn't be repaired with a Helicoil. It took 1 1/2 hours to get it out with no thread damage.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • Buzz Nichols
  • Buzz Nichols's Avatar
07 Apr 2023 16:13
#882630
Welcome! Pretty bike; looks like it's more or less all there. Getting it to run is certainly the right first step. Just my 2c, a good second step might be disposing of that fairing...
1978 KZ1000 LTD
  • TexasKZ
  • TexasKZ's Avatar
07 Apr 2023 20:29
#882651
If you plan on a lot of highway speed riding or taking any trips on the bike, you might just fall in love with that old Vetter fairing. It is a heavy beast, but is very well suited to its purpose. In cold or rainy weather, it will make a bigger difference than you might imagine.
