76 KZ900
- Moose1800
Re: 76 KZ900
13 Mar 2023 07:45I agree ! it's almost a given they will leak.You should split the carbs. The small rubber coated fuel Tee's are almost sure to be cracked and need replacing.
Re: 76 KZ900
13 Mar 2023 09:36I agree ! it's almost a given they will leak.You should split the carbs. The small rubber coated fuel Tee's are almost sure to be cracked and need replacing.
Or will soon. There's nothing worse than gas leaking on a hot engine, just below your crotch!
The following user(s) said Thank You: SWest, Wookie58
- mvent
Re: 76 KZ900
13 Mar 2023 13:50
That's the plan, for now they're going on to see how it runs shifts etc. Connected battery today after my key came in the mail and all good, starter spins, spark at plugs all lights and horn work, pleasantly surprised.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Re: 76 KZ900
13 Mar 2023 18:20
If the tees between the carbs are still in good condition you can revive them by soaking them in gasoline overnight. That will stop the leaks.
Re: 76 KZ900
14 Mar 2023 00:18
- slmjim+Z1BEBE
Re: 76 KZ900
14 Mar 2023 06:19 - 15 Mar 2023 05:46
Heat shrink may not survive long exposed to gasoline, especially when exposed to ethanol.
We 're aware of a process in which Teflon tape is wrapped around fuel tees to improve the seal. We have seen carbs on which it was done perform for many years with no leaks. Teflon appears to be quite resistant:to gasoline and ethanol:
www.calpaclab.com/teflon-ptfe-compatibility/
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 15 Mar 2023 05:46 by slmjim+Z1BEBE. Reason: Typo
Re: 76 KZ900
14 Mar 2023 08:20I did this shrink tube trick in 2017, no leaks.Heat shrink may not survive long exposed to gasoline, especially when exposed to gasoline.
The following user(s) said Thank You: slmjim+Z1BEBE
Re: 76 KZ900
14 Mar 2023 14:34
Seams either Teflon or shrink wrap the the carbs need to be unganged. At that point buy replacement tees or upgrade to aluminum or brass with ORings. Much cheaper/easier to change at the next rebuild.
The following user(s) said Thank You: slayer61, howardhb
- mvent
Re: 76 KZ900
17 Mar 2023 17:17
Got it fired up! Fired almost instantly, cylinders 1 and 2 are fine 3 and 4 not so much, once past half throttle clears up and pulls strong. No air filters on it, pulled carbs and will blow out carbs 3-4 with compressed air. Pilots jets are clear. Cold ccp before starting was 125 each cylinder and all plugs getting good spark. What should I expect for head pipe temps using a IR gun?
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Re: 76 KZ900
17 Mar 2023 19:00
The min./max. temp is irrelevant, all 4 cylinder/header temps should be equal as possible.
Re: 76 KZ900
17 Mar 2023 19:23 - 18 Mar 2023 16:28
Found my spare heat shrink tubed fuel tees. Just in case if you want to give it a try and save some money.
Last edit: 18 Mar 2023 16:28 by Scirocco.
- mvent
Re: 76 KZ900
18 Mar 2023 15:26
Thank you for the offer, I believe I have everything needed to reassemble when time comes.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
