76 KZ900
- slmjim+Z1BEBE
Re: 76 KZ900
10 Mar 2023 05:33
Very nice project bike! Low mile, one owner & appears unmolested. An increasingly rare combo these days.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Re: 76 KZ900
10 Mar 2023 08:07
Don’t be to quick to right them off. The internals look ok. The Schmutz on the outside should clean off. The worst I see is the adjuster cap. Im sure you can buy a replacement.
Re: 76 KZ900
10 Mar 2023 08:14correct for an early ‘76. Engine numbers started at 86001.
- krazee1
Re: 76 KZ900
10 Mar 2023 08:22Nice find indeed, I find it odd that it has early VM28's on it with it showing such low miles. Would be interesting to see the engine ID#.Very solid. Just FYI, it has Z1A-B carbs.
Installing the 28s was considered a performance upgrade at the time, at least by the kids I ran around with.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
Re: 76 KZ900
10 Mar 2023 08:25In my hood too Mike. My first 900 was a ‘76 LTD with a 1045 kit, and VM28SC carbs.Nice find indeed, I find it odd that it has early VM28's on it with it showing such low miles. Would be interesting to see the engine ID#.Very solid. Just FYI, it has Z1A-B carbs.
Mike
The following user(s) said Thank You: krazee1
- blipco
- 2002 KZ1000P
Re: 76 KZ900
10 Mar 2023 08:49
The slides look good, which is important. The rest just needs a good cleaning.
If the VM28’s were considered a performance upgrade, what was on there originally?
Re: 76 KZ900
10 Mar 2023 09:04
The following user(s) said Thank You: blipco
- blipco
- 2002 KZ1000P
Re: 76 KZ900
10 Mar 2023 09:05
Thank you, those look nice.
Re: 76 KZ900
10 Mar 2023 17:36The stock carbs were VM26SS, which I think were among the best ever installed on a Kawasaki. Some people said the top end wasn't quite as good as with the 28's. But the 28's are harder to synchronize...much harder. I have the '76 version on my 1980 KZ1000 LTD. I love them.The slides look good, which is important. The rest just needs a good cleaning.
- mvent
Re: 76 KZ900
12 Mar 2023 10:24 - 12 Mar 2023 11:54
Here they are after pine sol soak, dawn and hot water, mineral spirit bath then blown out with compressed air. All brass soaked in Berryman dip.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Last edit: 12 Mar 2023 11:54 by Street Fighter LTD.
Re: 76 KZ900
12 Mar 2023 11:28
Big difference. Nice job!
Re: 76 KZ900
12 Mar 2023 18:20
You should split the carbs. The small rubber coated fuel Tee's are almost sure to be cracked and need replacing.
The following user(s) said Thank You: blipco, sf4t7, Moose1800
