TheTrout's 78 KZ1000
  • TheTrout
  • TheTrout's Avatar Topic Author
Re: TheTrout's 78 KZ1000
19 Jan 2024 07:06
#894171
All of the aftermarket lines I have seen come with new banjo fittings already installed. You can buy bulk line and some fittings and install them yourself, but you will need a specific crimping tool to do that.
The Z1enterprises lines do not come with banjos.  They have threaded ends and they sell banjos with the threads to fit the lines.
1978 KZ1000B2
  • TexasKZ
  • TexasKZ's Avatar
19 Jan 2024 07:09
#894172
Yes, I looked just AFTER I posted that. Duh.
Here is a fully assembled option.
www.coremoto.com
  • JR
  • JR's Avatar
19 Jan 2024 09:41
#894180
If the old brake lines look like this then chuck em.  I'm pretty sure the banjos are crimped and not reusable.
I got those Z! Ent  Goodridge SS  lines plus banjos plus washers  (they are in the Fatbook)  from my local shop who I like to support and I cleaned up and reused the old  banjo bolts - Fatbook bolts have different - Harley?-  threads..
I like those lines. Everything went together very well and braking is much improved.
Just a note on measurements.  The line in the pic below is a 14 inch line. It is 14inches from red line to red line.
  • TheTrout
19 Jan 2024 12:14
#894182
Yep, I still got them old 45 year old original brake lines.  I'm thinking brand new everything.  Probably should rebuild the calipers too.  Any idea how hard a job it is to rebuild the calipers?
1978 KZ1000B2
  • JR
  • JR's Avatar
19 Jan 2024 15:51
#894185
Aah. Sorry cant answer that last question. Still on my to do list
  • Mikaw
  • Mikaw's Avatar
19 Jan 2024 16:10 - 19 Jan 2024 16:11
#894186
Caliper is straightforward. Nothing rocket science. If needed buy good stainless pistons and rubber from brake crafters. Keep in mind in order to take full advantage of the caliper rebuild the M/C’s need to be rebuilt also, at a minimum disassemble and clean. All very simple stuff. New braided lines and you will be sleeping in tall cotton for years
Last edit: 19 Jan 2024 16:11 by Mikaw.
  • TheTrout
11 Jun 2024 17:21 - 11 Jun 2024 17:27
#900616
I am getting ready to measure and order customer brake lines from Coremoto.  Can anyone tell me what size/type the banjo bolts are on a 1978 KZ1000B2 (LTD)?  The choices are 10mm x 1.0 and 10mm x 1.25, also the option of single length and double length.
 My guess is 10mm x 1.0 single length, can anyone confirm that?
Also wonder about measuring the lines.  I really don't want to take them all off to measure, mainly because I am not working this Saturday and want to get out for a ride.  How accurate do my measurements need to be?  I'd like to measure them on the bike if it can be done.  I was thinking of using some gas line to measure it.  Anyone done it before?
Side note - I took a second job as a barback at the local brewery.  I normally work every fuckin weekend.  I recently pissed off the bar manager and presto, only have to work on Sunday!  That is one to remember!
1978 KZ1000B2
Last edit: 11 Jun 2024 17:27 by TheTrout.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
12 Jun 2024 00:55
#900623
The banjo bolts = 10mm x 1.25
You determine the break line length following the routing (without the banjo fittings) with a string.
  • JR
  • JR's Avatar
12 Jun 2024 06:43
#900629
The Trout wrote
(I'd like to measure them on the bike if it can be done.  I was thinking of using some gas line to measure it.  Anyone done it before?)
Gas line should work. I used tv white coxial cable and a couple of zip ties. Easy to mark
  • TheTrout
12 Jun 2024 06:59
#900630
What is the angle of bend on the banjo fittings?  I can't tell if they are 10 or 20 degree bends.
1978 KZ1000B2
  • TheTrout
12 Jun 2024 16:29
#900641
I got my order in, went with 20 degree bends on the banjo fittings.  I sure hope that was right.  This was the one important thing I needed to get done on my bike.
1978 KZ1000B2
  • sf4t7
  • sf4t7's Avatar
12 Jun 2024 17:34
#900643
If you're replacing rubber brake lines you'll notice a big improvement with the braided stainless lines.  I converted to braided stainless brake lines on one of my bikes in the 1980's and it's been the first upgrade on every bike since.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
