- Thank you received: 2752
And finally, Wookie's 82 begins !
18 May 2024 15:10 #899263
by SWest
Replied by SWest on topic And finally, Wookie's 82 begins !
I was asking because there's not a lot of room in there even with the cooler high against the steering head.
- Thank you received: 2358
18 May 2024 15:26 #899265
by Wookie58
Replied by Wookie58 on topic And finally, Wookie's 82 begins !
I'm pretty sure with the horn mounts removed (using for the damper currently) it will be OK, I have some 90 degree fittings that will attach to the adaptorsI was asking because there's not a lot of room in there even with the cooler high against the steering head.
18 May 2024 15:39 #899266
by SWest
There seems to be a big difference in frames between the two. When I welded in the cross brace on mine I made it low close to the motor mounts so it wouldn't interfere with the pipes. As it turned out there was plenty of room. In your case you have it "boxed in" so I'm hoping they will fit in that cavity with plenty of clearance. Crossing my fingers.
19 May 2024 09:45 #899301
by Wookie58
Well it looks like the "gods of redneck engineering" have shined on me today
cutting the horn mounts off the frame gave me the clearance for the hoses (just) and with a new damper mount welded to the downtube we are back in business
I believe it was DocGamma that said "make it twice, make it nice" and I have to say in this case I think the MKII version of the damper mount is definitely an improvement, a good end to a busy weekend.
The following user(s) said Thank You: Injected, Rolf1976_KZ900
20 May 2024 12:05 #899386
by SWest
20 May 2024 12:14 #899387
by Wookie58
20 May 2024 12:21 - 20 May 2024 12:22 #899388
by SWest
Last edit: 20 May 2024 12:22 by SWest.
24 May 2024 06:37 #899630
by Wookie58
I know I'm a "cheap Wookie" but even I'm not immune to the odd "shiny extravagance". The postman brought these goodies today, That beautifully made cooler take off came from a company in Germany
The following user(s) said Thank You: Injected, slayer61, Scirocco, cartal, calum, Rolf1976_KZ900, Quofan
- Coyote
- Thank you received: 22
24 May 2024 13:39 #899659
by Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
Replied by Coyote on topic And finally, Wookie's 82 begins !
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- Thank you received: 2236
24 May 2024 18:10 #899669
by TexasKZ
Replied by TexasKZ on topic And finally, Wookie's 82 begins !
Which company did you buy the cooler manifold from?
25 May 2024 00:42 #899682
by Wookie58
The following user(s) said Thank You: TexasKZ
- Rolf1976_KZ900
- Thank you received: 159
25 May 2024 12:36 #899715
by Rolf1976_KZ900
Replied by Rolf1976_KZ900 on topic And finally, Wookie's 82 begins !
Is this manifoil fitted on the back side of cylinders where the oilmanifoil is fitted or on the cooler?
