KZ1000A1 Spare Parts Project 18 May 2023 12:37 #884857
  • calum
  • calum's Avatar Topic Author
  • Thank you received: 393
Well, the choke plunger levers disappeared at the platers so I've got the spares on. At least he did a good job on the brake caliper brackets so the front brakes are on as well.
Getting the carbs in was a major PITA. The 750 is so much easier.
The following user(s) said Thank You: Scirocco, Wookie58
KZ1000A1 Spare Parts Project 21 May 2023 04:55 #885019
  • calum
Just thought I'd post here that I'm in Exeter until Thursday. Just in case any of you UK guys are nearby and in the mood for a beer or two...
KZ1000A1 Spare Parts Project 21 May 2023 10:25 #885032
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1869
Bit far unfortunately (especially on a school night) shame as it would have been good to catch up
KZ1000A1 Spare Parts Project 22 May 2023 03:17 #885060
  • calum
Figured as much but thought I should let you know - not really sure where anyone's based over here.
KZ1000A1 Spare Parts Project 25 Jun 2023 07:17 #886380
  • calum
Been slowly working away at this. I now have everything except the bodywork and switch blocks done. Will get into the painting as soon as I've got the dent in the tank sorted and the tail sanded back down to the plastic..
No pictures today...
The following user(s) said Thank You: Wheelhop, Wookie58
KZ1000A1 Spare Parts Project 28 Jun 2023 08:33 #886569
  • calum
Scored a NOS rear master cylinder for cheap. Actually don't think it'll end up on the bike, though - it should really be put on an all-original build.
KZ1000A1 Spare Parts Project 01 Jul 2023 11:36 #886699
  • calum
Took the tank down the road to get a couple of dents pulled yesterday. When I was packing it up I noticed that the bracket for the tank cap is missing. Not sure why I never noticed before, must not have been paying attention.
If anyone has some scraps lying around from switching out the cap on an A1, A2 or 900A4 tank I'd be very grateful...
KZ1000A1 Spare Parts Project 01 Jul 2023 12:01 #886700
  • Wookie58
  • Wookie58's Avatar
  • Moderator
That sucks
KZ1000A1 Spare Parts Project 01 Jul 2023 15:27 #886709
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 262
But it could have been worse if you noticed after paint.
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
KZ1000A1 Spare Parts Project 02 Jul 2023 03:15 #886726
  • calum
Yeah, glad I noticed it - after painting would have been a nightmare.
Could someone out there please take the time to measure the following for me:
- OD and ID of the tube for the cap pin
- Width of the tube including the bracket
- Distance from the inside of the tank to the back of the tube (blue line)
- Top of tube to tank surface (red line)
If I have that then I can make a new bracket and get someone who is halfway decent at brazing to put it on the tank for me.
KZ1000A1 Spare Parts Project 02 Jul 2023 06:03 #886729
  • sf4t7
  • sf4t7's Avatar
Calum -
As it happens, my Z1A tank is hanging in my garage, primed and getting paint tomorrow !
OD tube   6mm
ID tube  2.7mm
Width including bracket  15.8mm
Blue line dimension  25.8mm
Red line dimension  16.1mm
Some additional info:
The thickness of the bracket material is  2.4mm
The roll pin is 2.65mm x 30.4mm long
You should probably use the roll pin dia to size the tube ID, since I got three measurements for the tube ID (gave you the middle one). As long as the tube ID isn't a real tight fit for the roll pin you use, your cap should hinge OK.
note: my Z1A tank latch mount looks a little different than yours (see photo).  The hole in the latch mount is 3.5mm up from the tank.  The filler neck stands 12.4mm above the tank.
You may need to adjust the red line dimension to get the proper fit for your cap.  I'm sure you plan to mock up with the cap before brazing.
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Last edit: by sf4t7. Reason: add info
KZ1000A1 Spare Parts Project 02 Jul 2023 07:41 #886733
  • calum
Thanks Scotty! I see that there are three different pins used on the Z1's and KZ1000's. I've been waiting for some parts on back order and the tank cap is in the same order. I just asked the guy to send the cap now so I can make sure it fits. With the pin and your dimensions I should be set.
