1982 Kawasaki KZ1000 LTD and CSR build
  • Jahimbi Blammo
  • Jahimbi Blammo's Avatar Topic Author
Re: 1982 Kawasaki KZ1000 LTD and CSR build
27 Sep 2021 18:15
#855855
I could really use some help on this next subject.  I want to reuse my stock pistons all of which are well within factory service limit except for one that is damaged.  I need 1 OEM piston.  I haven't had any luck finding one as of yet.  See attached pictures.  Thanks in advance.
2017 KTM 250XC-W
2015 Kawasaki KLX110L
2015 Yamaha FZ-09
2008 Kawasaki KFX 450R
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
28 Sep 2021 01:08
#855859
Wow, that is some head start you have got there. Some real nice work going on! as for the piston I’m sure there a few members on here that will have a spare piston, if not throw a shout out in the wanted section, that often helps, good luck from here in I’ll be keeping an eye on things with interest!
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
28 Sep 2021 04:08
#855860
Nice quality work! Looks like you already had the skills. Did you do the customization on the two cars in the background? Very nice indeed! Looking forward to seeing the finished project. Thanks for sharing.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • Jahimbi Blammo
28 Sep 2021 13:31
#855877
This isn't my first build.  I did a shadow bobber a few years back, some dirt bikes, that car.  This is the first time I've built a KZ.  I found such a good deal on the bikes that I couldn't pass it up.  I have a Kawasaki S2 also so the KZ will fit into the collection nicely.
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
  • BCScott
  • BCScott's Avatar
28 Sep 2021 13:54
#855878
Isn't that a '67 Skylark? My wife and I had one in the '80s.
Back in the saddle and loving it! KZ1000A1
  • Jahimbi Blammo
28 Sep 2021 17:10
#855887
You are very close.  It is a 1967 Buick Special that I have modified a bit.
I purchased it from a car dealer of all places for a very very low price in my opinion.  It was mostly restored already I just added the final touches.  Reliability was key to me.
WAIT A SECOND, I THOUGHT THIS WAS A KZ FORUM????
It has an actual Buick 455 big block which is pretty bad @55 in my opinion
TH200-4R transmission which has a very nice OD! (But I actually hate this transmission and want to replace it one day when I'm not building KZ's....)
I opted for installing a Holley Terminator fuel injection system so obviously along with that goes an entire new fuel delivery system which consists of a small, efficient, eco friendly 26 GALLON fuel tank!  (I really need gasoline prices to go down sooner than later : {
Earl's performance...everything...as far as fuel lines and fuel fittings go.
Eaton Posi with some 373's for the rear with all new axles, bearings, seals, so on.....basically bullet proof.
The stock brakes....sucked.  I replaced them with Wilwood 4 piston discs in all 4 corners.
and then I set this gigantic Granny tank on some Ride-Tech Shockwave air suspension...a few reinforcements and a sway bar here and there.  It's the ideal car to take to Walmart!!!! It will cost you about 10 gallons of fuel for the trip to Walmart, but who cares right?
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
The following user(s) said Thank You: DOHC, KZJOE900, BCScott
  • Jahimbi Blammo
28 Sep 2021 17:21
#855889
The car looks like this when it isn't laid out.  It can't really be driven laid out because the tires will rub against....everything.
Anyway, way off topic.  So the LTD engine was basically glued back together by someone using RTV as said GLUE.  Add this fun factor to the countless stripped out holes, busted off studs and bolts equals a real good time for me!!!
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
  • Jahimbi Blammo
14 Oct 2021 15:24
#856651
SO NOW THE FUN PART!
Time to start reassembling the bike!  This is always my favorite part getting to work with like new parts.  Nice and clean, easy to work with...just a fun time!
I have all the parts back from my powder coater and vapor blaster so I can start reassembling the bike and really determine what look I am going for.  I had both frames done - the textured coated one is the LTD I originally purchased.  The gloss coated one is the CSR I purchased as a parts bike.  I'm definitely  going to use the textured LTD frame and swing arm.  All new All Balls Racing bearings for the bike.  The wheels are at a shop getting fresh tires mounted  as I type.  Next step is to rebuild one set of forks and assemble a rolling chassis.
I CANNOT FIND A STOCK PISTON FOR THE ENGINE AND IT'S KILLING ME!  I need a piston to re-assemble the engine.
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
  • martin_csr
  • martin_csr's Avatar
14 Oct 2021 16:48 - 14 Oct 2021 16:59
#856653
Did you try EB for the pistons?
This one looks to be the same: item #223478794153.  There are a few others w the same part number (13001-1119).
The KZR EB function doesn't seem to be working.
Last edit: 14 Oct 2021 16:59 by martin_csr.
The following user(s) said Thank You: Jahimbi Blammo
  • 750 R1
  • 750 R1's Avatar
15 Oct 2021 01:30 - 15 Oct 2021 01:33
#856662
Yep, wouldn't let me post the link either but if you put the number into ebay the piston comes up...
Last edit: 15 Oct 2021 01:33 by 750 R1.
  • Jahimbi Blammo
15 Oct 2021 03:45
#856665
EXCELLENT!  I bought that piston  Thank you so much.  I have been scouring eBay, and internet in general with no luck so thanks again!  That is the last piece I need to get the bike up and running.
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
  • martin_csr
15 Oct 2021 06:30 - 15 Oct 2021 06:56
#856667
EB searches:  KZ1000 piston 1981. or 13001-1119. or other part numbers. or other terms such as KZ1000 CSR piston. etc.
1981 KZ1000-M1 CSR >> www.partzilla.com/catalog/kawasaki/motor...e/1981/csr-kz1000-m1
First thing I always do is check the diagrams at Partzilla, then search the full part number on EB.
Even if you're not looking to buy or the pricing is too high, NOS pics can be handy.
If there are no search results by part number, then search by part name.
Then by alternate part name >> something like a timing advancer or side cover can be listed in various ways.
Anyway, good luck with the motorcycle.
Last edit: 15 Oct 2021 06:56 by martin_csr.
