1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 14:08 #855837
  • Jahimbi Blammo
  • Jahimbi Blammo's Avatar Topic Author
  • Thank you received: 5
I purchased one complete 1982 KZ1000 LTD about a month ago and then a week after that I bought a partial 1982 CSR to be used as a parts bike.  Both bikes have titles.
I have to learn how to use this particular forum format so I'm going to submit this as a test post to see if it formats correctly and then continue on with the build...
2017 KTM 250XC-W
2015 Kawasaki KLX110L
2015 Yamaha FZ-09
2008 Kawasaki KFX 450R
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
Last edit: by Jahimbi Blammo.
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 16:43 #855842
  • Jahimbi Blammo
Okay I think I figured out the forum formats and stuff so here we go.
Again I'm combining an 82 CSR and an LTD into one bike using the best parts from the two.  Someone actually welded the gear shifter to the shaft so I had to cut that off.  I had to buy a new shifter and shaft
I apologize as I'm still trying to figure out how to insert pictures into a post.  I'll figure it ughhh
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 16:56 #855843
  • Jahimbi Blammo
I'm keeping the J engine basically bone stock.  I own very fast modern bikes so I have no need for this one to be a race bike.  I just want the classic KZ sound and a very reliable engine.  Nothing fancy here as far as the engine goes!
The carbs were not that horrible considering the years of neglect...but not good by any means.  I ordered a Dynojet Kit.  Installed it along with all new...well basically all new everything save the floats, chokes (enricheners, starter things, call them what you will)..so on.
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:04 #855844
  • Jahimbi Blammo
One thing that didn't make it into the last post is that I replaced all of the carb diagrams for a total of 12 dollars.  10 dollars for the diaphragm shipped directly from China and some extra money for some superglue....I just cut off the top retainer ring on the slide (leaving the bottom ring)  and then removed the old diaphragm.  Then put the new diaphragm onto the old slide paying careful attention to orientation.  Super glued it very carefully and it's a done deal.  Just like new.
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:13 #855845
  • Jahimbi Blammo
OH NO the engine from the LTD cannibalized something.
A clutchplate grenaded.  No damaga done to the bottom end.  OH...and look at the new shifter and shaft I mentioned in an earlier post.
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:29 #855846
  • Jahimbi Blammo
I ordered a custom seat off of eBay and I am very impressed!
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:32 #855847
  • Jahimbi Blammo
Cheap shocks from eBay
Cheap shocks from eBay mocked up
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:34 #855849
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
I am not familiar with those 1PZ filters, but be sure that the inner lip of the rubber part of the filter does not block any of the air jets or passageways in the mouth of the carbs. Some Chinese filters are known to do that, and they will cause endless headaches trying to tune the carbs.
The following user(s) said Thank You: Jahimbi Blammo
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:38 #855850
  • Jahimbi Blammo
Vapor blasting
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
The following user(s) said Thank You: KZJOE900
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:42 #855851
  • Jahimbi Blammo
Some tape,, some time, some flat black rattle can and ALL IS GOOD (at least enough for what I'm doing with this project :  ).
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:50 #855852
  • Jahimbi Blammo
rims, so many options so many configurations.  for now im going to stick with the stock mags.  A 16" in the rear and a 19" in the front.  So lets polish them up.
I might send the CSR rims out to CA to Buchannans and have a custom set made up but for now, Ima Stock it.
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
1982 Kawasaki KZ1000 LTD and CSR build 27 Sep 2021 17:55 #855853
  • Jahimbi Blammo
I'm having both frames Powder Coated.
The CSR
The LTD
I'll post the results.
2017 KTM 250XC-W
2015 Yamaha FZ-09
2005 Suzuki GSXR600
1999 Honda CR80R
1973 Kawasaki S2
