  • Page:
  • 1
Tire Load 11 Sep 2021 20:02 #855139
  • JacobJovan
  • JacobJovan's Avatar Topic Author
  • Thank you received: 0
Hello everyone,
I was hopping to get some advice regarding my Kawasaki 1978 kz650 cafe racer build. I currently have a 100/90-18 Kenda tubeless front tire rated for 494lbs and a 120/90-18 Kenda tubeless rear tire rated for 634lbs. The kz650 wet should be somewhere around 480lbs. I’m 6’0ft 175lbs… so the total weight limit obviously exceeds the tire load limit.
Should I buy new tires? Should I just play it safe until these get worn out? I don’t plan on riding crazy. I’m guessing it’s better to be safe than sorry and just buy some new tires, but I wanted some opinions before.
Tire Load 11 Sep 2021 20:26 #855140
  • Thank you received: 2829
Add the two tire ratings together to get the total allowable load.  You are not even close to it.  Ed
Tire Load 13 Sep 2021 04:19 #855203
  • JacobJovan
Thank you so much! That makes a lot more sense.
Tire Load 13 Sep 2021 08:07 #855213
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 143
I bought a cheap bathroom scale I keep in the garage. Add front tire to rear tire weight to get total weight of bike. My scale only goes to 300lb, so I can't test weights with me on the bike.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
Tire Load 13 Sep 2021 18:01 #855239
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 381
You surely can weigh you and your bike with a bathroom scale.
I weighed my Chevy 1/2 ton with a $20 Wal-Mart 300lbs max digital bathroom scale.
You have to use a lever.
mechanicalelements.com/tricks-to-weigh-trailer-or-heavy-things/
81-KZ440-D2.
LIC, NY
Last edit: by F64.
  • Page:
  • 1
